586,640 active members*
2,432 visitors online*
Page 2 of 17 123412
Results 21 to 40 of 327
  1. #21
    Oct 2003
    927
    Quote Originally Posted by RMHCNC View Post
    It is a ER11 colet with 8mm shaft, I removed the shaft from the outrunner and installed the ER11. It takes some minor mods like grooving the colet for the retainer clips but seems to work well
    could you elaborate on the conversion procedures for fitting the ER-11 shaft into the outrunner motor? I'm not yet familiar with the outrunners but you have made good use of it as a spindle.
    Thanks!
    Shoptask rebuild:
    http://www.cnczone.com/forums/showthread.php?t=2139
    Home built gantry router:
    http://www.cnczone.com/forums/showthread.php?t=5049
  2. #22
    Jun 2011
    Re: My desktop cnc with home made spindle
    I must ask. Do you have the PCB schematics for the bob and Vreg?
    Kevin.
    Nsr customs.
  3. #23
    Apr 2012
    230
    Bloy
    The outrunner has an 8mm shaft and the shaft of the ER11 is also 8mm
    You must carefully disasemble the out runner and press out the shaft
    Then place a grove in the ER11 like the outrunner shaft
    Press in the ER11 and assemble the motor.
    NSR
    Yes I have them in PDF format I just need to find a way to get them to you, pm me a email addy and I will send them your way
    http://youtu.be/9dTS1A2F4j8
  4. #24
    Jun 2011
    Sent. Thx
    Kevin.
    Nsr customs.
  5. #25
    Jun 2011
    Just curious if you knew why they used a 470pf cap on pin 7 I have seen 100pf and 330pf used but not 470.
    Kevin.
    Nsr customs.
  6. #26
    Apr 2012
    230
    Not sure myself and that's why I followed the data sheet and used a 330pf i did a mix of what they used and what the data sheet required. I also used only 10 x 1 ohm resisters instead of 12 to limit the driver to 2.5 amps
    I will put them PCB lay outs together for ya after dinner
  7. #27
    Jun 2011
    That works. I am having a hell of a time finding 330pf in my stuff.. I was @radio shack today and didn't even think about it...
    Kevin.
    Nsr customs.
  8. #28
    Jun 2011
    Well I spent the last 3 hrs tracing circuits on the 4 axis board and I still can't figure out why my x axis is screwy so I pulled the 6560 chip off and I'm gonna stick another one in. If that dont fix it ill start collecting materials to etch some pcbs. If it does fix it ill see if I can't mill out the pcbs either way I'm gonna ditch the poorly designed board for one that's more usable and fixable...
    Kevin.
    Nsr customs.
  9. #29
    Apr 2012
    230
    Reg board parts list
    1 LM338 reg
    4 7805 regs
    1 7812 reg positive and negative are reverse on the outputs
    4 LEDS
    1 1000 uf 25v
    5 1000 uf 16v
    6 .1 uf
    5 240 ohm resistors
    1 5k pot
    5 Main CAPSs are 2200uf 35v for motors only
    Screw Terminals
    Hope didn't miss anything lol
  10. #30
    Jun 2011
    Got Ur email. Do u have the bom for the breakout board?
    I have not opened the files yet cuz I mainly use my phone for forum and email so if their in there just ignore me.. lolz
    Kevin.
    Nsr customs.
  11. #31
    Apr 2012
    230
    Hold off on the bob just for now I may change it do to a ground issue on 1 of the ic's will let you know ASAP
  12. #32
    Jun 2011
    no problem. i believe you had said you were etching yours? im trying to find a way of converting it to an nc file to machine it. any ideas?
  13. #33
    Apr 2012
    230
    I use NC files for my laser and use Inkscape and a modified version of gcode tools plug in.
    If ya need something I will try and find the link that will explain the process and where to get the files needed.
    My laser cnc runs Grbl 8.0 on a arduino nano and 2 easydrivers
  14. #34
    Apr 2012
    230
    That program is a great little tool for fast simple boards but the output options are garbage.
    Can't beat free though lol
  15. #35
    Apr 2012
    230
    Well with all the trouble I'm having with the bob I decided to just order a $14 eBay job and will continue to work on its design later on. Don't want to risk my pc at the moment. Everything works well when I test the drivers with my arduino nano for controlling the step dir and enable so why waist time lol
  16. #36
    Jun 2011
    That works. I thought about ordering one too. Making one is almost pointless when the price is so low.
    Kevin.
    Nsr customs.
  17. #37
    Apr 2012
    230
    You got it man, the only thing that sucks is the wait time.
    It looks to be the same manufacturer as the CNC board that failed on me so I hope the thing works lol.
  18. #38
    May 2009
    39
    Your project and the 8mm shafted outrunner has had my mind thinking for the past few days on a different approach to a "personal" cheap ATC. Rather than switching the tool itself out and everything involved with that (since the supporting hardware and specific tool spindle requirements generally cost many time more than the average hobby cnc setup many times over)
    Why not simply run 2, 3 or even 4 of these motors and keep each loaded with it's own dedicated tool. And rotate the entire motors assembly tool and all into task. I have nothing firmly in mind but perhaps a round rotating plate with angled mounts for each motor. Not as elegant as a ATC or offering as many cuttings choices loaded up, but far more affordable and far simpler for us hobby level guys.
    I suppose the biggest issues would be speed controller wiring or rather how to deal with the rotating motors and the connections to the setup........
    The outrunners are just nice and compact and not in the 3000 dollor price range each, not even close.
  19. #39
    Apr 2012
    230
    That is just to funny my friend because that's what I have in mind. Further down the road if this setup works well then I will use it to build version 2.
  20. #40
    May 2009
    39
    Great minds think alike they say....lol.
Page 2 of 17 123412
  1. Home Made internal spindle stop!
    By widgitmaster in forum Mini Lathe
    Last Post: 08-13-2016, 10:46 PM
  2. Home made electronic for Spindle control
    By dinko in forum CNC Machine Related Electronics
    Last Post: 05-31-2012, 02:52 PM
  3. 100000 rpm spindle home made
    By goldi80 in forum Hobby Discussion
    Last Post: 10-14-2011, 03:43 AM
  4. My home made cnc - Need a good spindle?
    By Rajpage in forum DIY CNC Router Table Machines
    Last Post: 11-02-2010, 09:03 AM
  5. Hard drive servo spindle are any good for home made lathe?
    By patriciooholegu in forum Servo Motors / Drives
    Last Post: 12-08-2007, 04:48 PM
