586,106 active members*
2,987 visitors online*
Page 1 of 17 12311
Results 1 to 20 of 327
    Apr 2012
    230
    My desktop cnc with home made spindle
    Just finishing up odds and ends and then it's time to build the drivers.
    I plan on using TB 6560 IC's, I purchased the three access CNC board from China as most of us did and was not happy with any of the results. A ton of motor noise and plenty of skipped steps. I have five ICs on Hand and hope I can build at least three working drivers. Logic and motor power will be controlled with manual toggle switches in order to try and meet the data sheet information. Any help with the ICs would be greatly appreciated.
    Pictures to come cant upload from my phone
    http://youtu.be/9dTS1A2F4j8
    Apr 2012
    230
    Apr 2012
    230
    lol that didnt work out.
    if the link takes you to my google account look in the photos and you will see the pics
    Apr 2012
    230
    I can't for the life of me get pictures in my post but all is well
    The bed and all is ready, just working on the electronics. U have built and tested a prototype TB6560 driver and happy with the results so for. I turn on the logic power first count to 30 and then energize the motor voltage. No hiss or motor sound and smooth operation what I need now is a single sided BOB I can build that has full isolation.
    Apr 2012
    230
    Well I decided to start a blog and uploading pictures is no longer a problem. follow the link if you want to see my progress Diy Desktop CNC
    Apr 2012
    230
    here is a video of me testing the spindle controls
    Diy Desktop CNC
    Jun 2011
    Re: My desktop cnc with home made spindle
    How did you attach the chuck to that outrunner ?
    Kevin.
    Nsr customs.
    Apr 2012
    230
    It is a ER11 colet with 8mm shaft, I removed the shaft from the outrunner and installed the ER11. It takes some minor mods like grooving the colet for the retainer clips but seems to work well
    Jun 2011
    Do you have a link to where u got it? I got a few outrunners in my pit box I wannna mess with.
    Kevin.
    Nsr customs.
    Apr 2012
    230
    I got it off eBay http://shop.mobileweb.ebay.com/searc...T+SHANK+COLLET
    Just make sure your outrunner has an 8mm shaft and you should be good to go
    P.S it does not come with the colet inserts so you will have to get a set of them also http://item.mobileweb.ebay.com/viewi...id=09306036266
    Apr 2012
    230
    So! Any luck? @ N.S
    Jun 2011
    I found a couple on there but I'm working on getting my spectralight running before I delve into another project.
    Kevin.
    Nsr customs.
    Apr 2012
    230
    Cool,cool what's the issue your having getting going if any?
    Jun 2011
    Crappy 3axis tb6560 driver board blew up. Working on swapping in my backup 4axis and hoping it doesn't end up the same way...
    Kevin.
    Nsr customs.
    Apr 2012
    230
    My best advise is don't go past 24 vdc for the supply voltage and lots of air flow close to the regulators on the board, also power the fan that's on the heat sink by another source it will help with the skipped steps issue and set your TQ to 75%
    I built my own driver boards and don't push them past 2.5 amps because that is their continues rating, 3.5 amps is peak and with 100% TQ settings your bound to blow more chips
    I will gladly give you my pcb layout I found if you end up needing to salvage some of what your left with
    Jun 2011
    yea i have a 24v 15a psu and i have removed the fan plug and added another 12v source for it. i also followed the mod on the fixed tb6560 thread by adding another 74hc14 after the optos and disabling the idle current mode circuit. im looking to source some 330pF caps for the internal clock and i added the diode to the spindle relay(not even using it yet).. lolz but i hadnt heard anything about current setting to 75%. im using stock spectralight round motors so ill try that.
    i have looked into making new drivers. im trying to find a pcb layout for a break out board that i can drop the optos and other stuff onto so if i get more parts i can build drives. but i would still love to see your layouts.
    Apr 2012
    230
    http://reprap.org/wiki/File:Heavy_Me..._schematic.pdf
    http://reprap.org/wiki/File:Heavy_me...driver_PCB.pdf
    The first link is for the drawing an the second is for the PCB
    Diy Desktop CNC this is what it looks like when put together
    Jun 2011
    I like that layout. Nice and neat. I may have to make a few of those.
    Kevin.
    Nsr customs.
    Apr 2012
    230
    Yes I searched for countless hours and came across the board. Works well for me so far. I have yet to build the hole controller. I have the BOB, Drivers and pwm control done but want to build a power distribution board so each PCB has its own regulated power.
    Apr 2012
    230
    So I have bin plugging away at this controller non stop for the past few days and have got alot done I completed all the PCB boards and mounted them to the base of the enclosure Ran most of the wiring and have powered it up for testing. Glad to say no puffs of smoke and all seems well I will post more as I go
    Pics Diy Desktop CNC
Page 1 of 17 12311
  1. Home Made internal spindle stop!
    By widgitmaster in forum Mini Lathe
    Last Post: 08-13-2016, 10:46 PM
  2. Home made electronic for Spindle control
    By dinko in forum CNC Machine Related Electronics
    Last Post: 05-31-2012, 02:52 PM
  3. 100000 rpm spindle home made
    By goldi80 in forum Hobby Discussion
    Last Post: 10-14-2011, 03:43 AM
  4. My home made cnc - Need a good spindle?
    By Rajpage in forum DIY CNC Router Table Machines
    Last Post: 11-02-2010, 09:03 AM
  5. Hard drive servo spindle are any good for home made lathe?
    By patriciooholegu in forum Servo Motors / Drives
    Last Post: 12-08-2007, 04:48 PM
