586,117 active members*
3,606 visitors online*
    673
    4th axis indexing?
    So about to program a part cut on all sides. I decided to use 4th axis to do rather than multiple vise setups. So do I just create a new coordinate system for each side, and it will know I'm trying to A index it, or is there some other trick I need to do?
    Thnx
    Oct 2007
    499
    Your post processor needs to be set up for prismatic machining. From the SolidCAM side of things, it depends on how your post is set up; for a part which uses just one work offset and say G68 or PLANE SPATIAL to position the rotary axis you have MAC 1 with multiple positions, for using separate work offsets such as G54, G55 etc. it is best to use MAC 1 pos 1, MAC 2 pos 1 and so on.
    Then if you have a simultaneous fourth axis it is a very different kettle of fish.
    673
    Quote Originally Posted by Brakeman Bob View Post
    Thanks.. I need to check the post processor, but I meant in solid cam itself. Assuming I'm using one offset, how do I get it to select the "back" side.. when I select the back of the cad model, it still wants to use the front face as the reference.....
    Oct 2007
    499
    In SolidCAM for 4th axis indexing, and a new MAC position with the Z axis pointing the wat you you want the too to approach from. Then make sure that is one referred to when defining your 'turnover' geometry.
    For 4th axis simultaneous, there are two methods. The first is to define a 'WRAP" transform and the other is to use a 5 axis job. This latter method is far more powerful.
    673
    Got it. thanks.. will give it a try.. just doing 4th axis indexing for the forseeable future...
  1. Replies: 2
    Last Post: 01-06-2013, 03:08 AM
  2. 4 axis indexing
    By aldepoalo in forum BobCad-Cam
    Last Post: 11-02-2012, 04:50 PM
  3. Indexing on the 4th axis
    By bevinp in forum SprutCAM
    Last Post: 08-20-2010, 09:29 AM
  4. indexing 4th axis
    By 69ss396 in forum Haas Mills
    Last Post: 12-03-2008, 10:06 PM
  5. 4 axis indexing
    By camtd in forum PTC Pro/Manufacture
    Last Post: 05-12-2006, 01:20 PM
