Originally Posted by
Milton
I have a peace of aluminum that I want to mill out to replace some parts on my router.
It is 1/4" thick and do not know what grade it is, Got it at the recycle and it is harder than a lot of the other aluminum I hove got there before.
The peace to be cut is just a simple rectangle peace with a few holes in it.
Will be using a 1/8" up cut flat tip milling bit.
Would like to know what would be a good cutting dept and speed to do it. If you use nothing at all, you may have the aluminum stick to the endmill/bit and then it will break. T=You are using a two flute, right?
Right now I have it set up for 20" a min. with six passes at .040 each pass.
Need advice if the set up will work or do I need to change it.
There is no cooling or oil for the cut but was thinking about spraying it with silicone spray as I cut it. ????
Milton
It is nearly impossible to give a really good info, as we have no idea of the size and rigidity of your mill. But, I would say that you may be okay with that set-up. Yo8u might test it at 10 ipm to start.
I would find a little bit of soluble oil and mix it and spray some on as you go.
You do mean a 1/8" endmill don't you?
Mike
