586,077 active members*
3,679 visitors online*
    Nov 2006
    12
    Puma 2600y g17 milling
    We recently got a PUMA 2600Y and this is the first time we are trying to use it for milling on the face. its a simple part with 2 lugs on the face that we are trying to interpolate with an endmill. my first issue and the lathe department doesnt seem to grasp this is that the X is positioning to diameter not radius. second issue is i get an over tolerance alarm when i use g02 g03 straight from a posted out milling pattern. i got it to work typing a simple straight y move, g02 with a r.01 (it didnt like using I and J), then X, then Y again. The part is simple and i can get it to work by fudging it but i know that pieces are going to start getting more complex. any help on this issue would be greatly appreciated. I have no info at all in the programming manual (i feel as though we are missing books because live tooling is not covered at all)
    2932
    Maybe this will help.
    Attached Files Attached Files
    May 2008
    77
    Can you post that section of your program? I'm curious to how you programmed it. I have experience using over tools on lathes, perhaps I could help. I'm just having a hard time following what you're trying to do without pictures
  1. 88 puma 6 or 10
    By Cartel, LLC in forum Daewoo/Doosan
    Last Post: 11-30-2010, 04:07 AM
  2. Puma 8
    By Willydke in forum Daewoo/Doosan
    Last Post: 03-09-2010, 04:23 AM
  3. Puma 230MSB and thread milling
    By 2alpha in forum Daewoo/Doosan
    Last Post: 10-16-2009, 08:11 PM
  4. NEED HELP WITH PUMA 200
    By CNCBEN in forum Daewoo/Doosan
    Last Post: 09-16-2009, 04:52 PM
  5. Puma
    By M-man in forum Daewoo/Doosan
    Last Post: 05-14-2008, 03:25 AM
