587,047 active members*
2,695 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC Swiss Screw Machines > Question regarding programming Citizen with Partmaker
    Oct 2011
    65
    Just wandering when Partmaker outputs program it is a .cnc file. But I have to load a .prg on my Citizen. Is this correct and if so how do I go about doing it
    Jan 2013
    You should be able to set defaults to post it as a .txt file, if not then generate the code with the post processor. SAve it in Notepad as a .TXT in both the file name and the file type. Save it on the flashcard and drop it into the controller.
    For sure though send me some samples about your MC-data and ill help you. If you do not "structure" the machine within partmaker to what your modular tool block setup is then you will get alarms on the machine when you load the program into it.
    304
    Just RIGHT CLICK on the file name and choose "RENAME". Delete the ".CNC" and change it to ".PRG"
    If you do not see the ".CNC" when you look at the file then there is a setting in your computer that is set to Hide File Extensions. Change that.
    Dec 2008
    54
    Contact [email protected] and we can change it so you get a .prg extension.
    Bill Cain
    www.partmaker.com
  1. Programming help with Citizen A32VII
    By sthuston in forum CNC Swiss Screw Machines
    Last Post: 10-19-2018, 07:27 PM
  2. partmaker swisscam question
    By drbutch in forum Uncategorised CAM Discussion
    Last Post: 01-24-2013, 02:42 PM
  3. Citizen A20 question
    By maliveline in forum CNC Swiss Screw Machines
    Last Post: 10-26-2012, 01:46 PM
  4. Newbie to Citizen and bar feed programming
    By gizmo_454 in forum CNC Swiss Screw Machines
    Last Post: 02-25-2011, 08:25 PM
  5. Citizen K16 programming
    By bvaught in forum CNC Swiss Screw Machines
    Last Post: 07-03-2008, 12:51 PM
