586,352 active members*
3,339 visitors online*
    Sep 2006
    222
    Mori MT lower turret problem
    Machine: Mori MT2000 -2003
    Problem:lower turret does not index.
    Here's MR Moris instruction:
    MT2000 Lower Turret Zero return procedure
    Initial Procedure
    1) Check that turret is in unclamped condition (if not enter adjustment mode and
    unclamp) (See steps 2, 3 and 5 of Master Reset Procedure)
    2) Press “Turret Rotation” and “Plus” buttons together once – the turret will move 1 turn
    of the motor
    3) Press “Turret Rotation” and “Plus” buttons together again until station 1 is at correct
    position – when this happens turret will automatically clamp (if clamped then position
    is set ok)
    4) Turn off power and back on
    Master Reset Procedure (only use if above does not work)
    1) Remove ALL live tools from turret disc
    2) Put machine in adjustment mode (Feedhold button and Edit key)
    3) Set PC parameter D149.5 to 1 (Turret adjustment mode) and D149.6 to 1 (Live Tool
    adjustment mode)
    4) Check diagnostic X11.1 = 1 (gearshift is turret side) if NOT press “Turret Rotation”
    and “Turret Plus” button (“Turret Minus” button – Milling side) (Y11.3 =Turret side /
    Y11.4=Milling side) (see note below)
    5) Turret unclamp is by turret “Plus” button, Turret clamp is by turret “Minus” button
    6) Press “Reset” button
    7) In manual mode press “SPJ” spindle jog button to rotate the turret
    8) Make the turret rotate more than 1 revolution and then stop it so that the dimple is 10
    to 20mm away from the station 1 marker arrow. See below
    10-20mm
    FAQ SV02-022-04-004 2/2
    9) Press spindle normal rotation button and the turret will index to station 1
    10) If the mark and the dimple do not line up press “Reset” and then “SPJ” button to
    rotate and then follow step 8 again.
    11) If marks are inline set the two PC parameters D149.5 and D149.6 to 0 – TURRET OK
    12) If the marks are not inline set D149.5 and D149.6 to 0 and press “Turret rotate” and
    “Turret Plus” buttons to step turret to station1
    13) Turret will clamp automatically.
    14) Power off control and back on to clear adjustment mode
    15) Press turret index and turret plus button to index turret one station at a time and
    check operation.
    16) If motor is removed or correct position is not achieved change D1518 to set orientation
    zero position. (THIS IS NOT NORMALLY REQUIRED FOR ANY OTHER TIME)
    Everytime when leaving mark about 10-20mm and after that pressing spindle rotation marks are not inline. I have tried several times but no luck.
    Somehow it seems to be about one tooth off from correct position.
    D1518 info is in binary mode. But i dont understand because there is sensor for Turret station 1..it should find it. What i'm doing wrong or do i have to start to change D1518
    Jan 2012
    59
    Do'nt feel bad we have a brand new NTX1000 we have the same kind of
    everything has to be in the right place and locked trouble.
    Without Esprit we would be screwed.Still takes two days to setup a simple part.
    It is a pretty cool machine once it is running.
    Feb 2009
    6028
    Just turn on the turret adjust parameter, unclamp using the +/- button, hand wheel the turret to station 1 and get it to clamp with the same +/- button and toggle 1815.4 in the parameters. The procedure you have works if you've done it 10 times before.
    Jan 2023
    Re: Mori MT lower turret problem
    Old thread, still relevant. Has anyone had a shift issue where when the turret is clamped the shift from turret indexing to live tooling doesn't happen smoothly or not at all? I think I need to make a shift in where the turret clamps so the gears align correctly in the shift mechanism. The clamp location is pinned I believe so i'm not sure what needs to be adjusted.
  1. Parking the lower turret
    By Dan B in forum Esprit
    Last Post: 01-25-2013, 08:12 PM
  2. C-axis help on the lower turret
    By JBeeker841 in forum Daewoo/Doosan
    Last Post: 04-28-2012, 06:47 AM
  3. Mori MT200SZ lower turret
    By Green Button in forum Mori Seiki lathes
    Last Post: 06-09-2011, 03:28 PM
  4. Mori AL-2 Turret Indexing and X Home Problem
    By krfrea in forum Mori Seiki lathes
    Last Post: 01-03-2011, 07:59 PM
  5. Lower turret won't feed
    By bvaught in forum Uncategorised MetalWorking Machines
    Last Post: 11-17-2004, 12:46 AM
