Hello everybody !
I have to solve the download and upload programs from PC to Fanuc 18i-T CNC. Somebody tried before to solve it but the result was 0 and now I see that the serial port #1 of CNC is damaged . I use the standard db25/db9 cable described in fanuc manuals, software handshacking .
My questions are :
1. Can I use the second serial port through channel 2 with appropriat parameters setting to communicate with the PC ?
2.To transfer files it is necessary to use a dedicated program or it can be made with a common serial communication software, eg terminal,hyperterminal,etc ?
3 .When I want to read files from the PC , after pressing "read",filename,"exec" the screen has no change, no blinking "LSK", nor"input" on lower right corner and no errors!! Why ??
Same when trying to "punch"
Par. 3202 has set bits 0 and 4 to "0" to enable the program handling.
par 20 is set 2
pars 121-123 are set for 9600-e-7-2 .
4. Why the CNC does not even try to send or receive ??
Glad if someone could give me some advice.
Best regards
dipl.eng.Richter Zoltan
