586,708 active members*
2,477 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > V21 . cut depth off by amount of safe height
Results 1 to 9 of 9
    Oct 2006
    157
    I have 2 suites of v 21 .
    1 on my lap top - works good.
    2nd one on computer in the shop.
    I have compared both back and forth and can't seem to figure this out.
    The 2nd one,
    when you want to have a complete z cut depth of .5" and a tool safe height of .1" the last z movement is .6" (it adds the 2 together)
    My cut depth is set as a negative and the safe height is set as a positive.
    What are your thoughts?
    Thanks!
    Jan 2013
    Re: V21 . cut depth off by amount of safe height
    Maybe I am missing something, but this sounds correct to me.
    You have told the machine to cut 0.5" (that is 0.5" down from Z=0) or a negative Z. You then want the tool to return to safe Z which you have defined as +0.1". The distance between -0.5" and +0.1" IS 0.6"
    Mar 2010
    1852
    Quote Originally Posted by GBowes View Post
    Only in incremental mode.
    Two Haas VF-2's, Haas HA5C, Haas HRT-9, Hardinge CHNC 1, Bother HS-300 Wire EDM, BobCAD V23, BobCAD V28
    Oct 2006
    157
    Take a look at this .
    Just a simple 2inch long cut.
    Programed to a depth of cut of .5" deep.
    Top program does it correct (lap top computer)
    Bottom program does it too deep ( shop computer)
    ***(Check out line N80)***
    (This one is from my lap top)
    N10 G17 G20 G40 G49
    N15 G55 G80 G90 G94
    N20 G53 G0 Z0
    N25 X0 Y0 M5 M9
    N30 (2 inch line at .5" depth,Load Tool 1)
    N35 M0
    N40 T1 M6 G43 H1
    N45 S1000 M3
    N50 Z0.1
    N55 X1.
    N60 G01 Z-0.25F1.5
    N65 X-1. F8.0
    N70 G00 Z0.1
    N75 X1.
    N80 G01 Z-0.5F1.5
    N85 X-1. F8.0
    N90 G00 Z0.1
    N95 G53 G0 Z0
    N100 X2 Y2 M5 M9
    N105 M2
    (This is from the shop computer)
    N10 G17 G20 G40 G49
    N15 G55 G80 G90 G94
    N20 G53 G0 Z0
    N25 X0 Y0 M5 M9
    N35 M0
    N40 T1 M6 G43 H1
    N45 S1000 M3
    N50 Z0.1
    N55 X1.
    N60 G01 Z-0.25F1.5
    N65 X-1. F8.0
    N70 G00 Z0.1
    N75 X1.
    N80 G01 Z-0.6F1.5
    N85 X-1. F8.0
    N90 G00 Z0.1
    N95 G53 G0 Z0
    N100 X2 Y2 M5 M9
    N105 M2
    Mar 2010
    1852
    If you are using the same part file to post with and I mean taken from one computer to computer without change, then it is the post processor. Copy the post processor from the laptop and replace the one on the shop computer.
    It should be the same then.
    Mike
    Oct 2006
    157
    Same post prcessor.
    They used to do the same output but somewhere along the lines I must have goofed it up.
    Any idea's where ?
    May 2008
    244
    Airchunk
    go back to setup
    under drivers general tab
    make sure incremental xyz is (not) checked should fix it
    dw
    Oct 2006
    157
    Hmm , good idea .
    I will go check !
    Oct 2006
    157
    dwood
    Thanks so much!!!
    You NAILED it!
  1. facing amount
    By elsanch in forum News Announcements
    Last Post: 06-22-2012, 12:09 PM
  2. Relative safe travel height and potentially other suggestions
    By jm82792 in forum Uncategorised CAM Discussion
    Last Post: 02-11-2012, 08:54 PM
  3. Replies: 2
    Last Post: 02-04-2012, 05:27 PM
  4. water table depth and height of slats?
    By bseibenick in forum Waterjet General Topics
    Last Post: 12-08-2008, 06:00 PM
