603,810 active members*
2,556 visitors online*
    Nov 2009
    5
    Cool single axis driver connection question
    Hi everyone, I have a question about how to connect a single axis driver board to the parallel breakout board. On my first cnc board there is 3 connections for each motor, step, direction, and enable. On this single axis driver board there are 6 connections for +and - step, +and- direction, and +and- enable. My guess is to connect to the + terminals and ground the -'s to the common or ground terminal on the breakout, is this correct or not. Please advise, Aloha, Duane
    Mar 2007
    2083
    your first board must of had 4 connections for each axis
    ( the fourth connection may of been a common connection to the printerport ground )
    if the common output on your breakout board is ground / 0V
    connect all the negative stepper driver inputs to the common terminal (- step , -dir , -enable)
    then connect the BOB's step , direction and enable outputs to the driver positive inputs as required (+ step , +dir , and + enable )
    note the enable input is usually negative logic ( active low)
    with no signal or if you don't make any connections to the stepper driver enable input the driver will work
    if the BOB common output is +5V
    connect the + step ,+ dir and + enable to the +5V common
    and the BOB outputs to - step , -dir and - enable
    you will need to set up in the control software
    the step and direction as active low and the enable as active high
    John
    Nov 2009
    5
    Quote Originally Posted by john_100 View Post
    John
    Aloha John, Thanks so much for the quick reply, I understand, my breakout has a jumper to set the common and now I understand that better too, Thanks again, Duane
  1. Single Axis TB6560 driver and breakout board wiring
    By badboy in forum Stepper Motors / Drives
    Last Post: 07-10-2012, 11:26 PM
  2. Tachus42 Single Axis Driver
    By wickedweed in forum CNC Machine Related Electronics
    Last Post: 01-04-2012, 05:08 PM
  3. ِA Question about 3-Axis PIC12C508A Stepper Driver
    By waleed alhadidi in forum Open Source Controller Boards
    Last Post: 08-03-2011, 09:30 PM
  4. 3 axis stepper motor driver using a single PIC
    By david90 in forum PIC Programing / Design
    Last Post: 04-06-2008, 03:22 AM
  5. single axis driver and a b.o.b.,or multi-axis driver board
    By .xXACEXx. in forum Stepper Motors / Drives
    Last Post: 07-03-2007, 05:13 AM
