586,106 active members*
3,134 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > TB6560 using a 5 wire bipolar motor
    Jan 2013
    I have a TB6560, and it runs my bipolar motors fine.
    I was given some uniploar motors step-syn 103-771-18 5 wire.
    Tried to run them with the coil common unhooked,switched all around and came up short. I am using Mach3.
    Anybody get these working with the TB6560?
    Also, Is there a express 34 card out there that will run driver using a laptop and settings?
    Jan 2010
    2141
    I have no information about your specific motor, however the typical 5-wire motor will not work with a bipolar driver because the center taps of both windings are connected together internally within the motor.
  1. Wiring 8-wire motor as bipolar series and setting current!
    By whitewittock in forum Stepper Motors / Drives
    Last Post: 07-13-2012, 09:29 PM
  2. TB6560 3 Axis 6 Wire Nema 23
    By catabolic in forum Stepper Motors / Drives
    Last Post: 07-03-2012, 04:57 PM
  3. Disadvantages of 6 wire Bipolar Scheme
    By cnc kiwi in forum Stepper Motors / Drives
    Last Post: 10-27-2007, 08:10 PM
  4. 5 wire steppers-bipolar drive
    By obscurity in forum Stepper Motors / Drives
    Last Post: 12-04-2005, 01:00 AM
  5. Can you wire bipolar...
    By WilliamD in forum Stepper Motors / Drives
    Last Post: 10-10-2005, 07:48 PM
