Originally Posted by
aarongough
The plan is to have spindle indexing, but no 'true' C-axis... I'm going to setup a spindle brake (of a type yet to be decided) and any cuts with live tools will be done with the spindle brake engaged.
Electroid make a nice line of electro-magnetic brakes.
You can also get motors with brakes on them.
The brake and encoder can only be on the motor if the coupling is a tight single type, timing belt etc, not gear head or other, if this is the case then you need the encoder and brake on the final spindle shaft for C axis control.
Al.
Albert E.
