My Alpha LE950 Laser carriage is not moving.
Carriage moves manually with power off, Limit switches test is ok, Voltage test shows steppers are OK. Work area is correct
On the Main board the run light is off ...it only lights on power up.
On startup it beeps for about 10 sec. then later another beep like it's doing it's startup routine but the carriage does not move.
Laser is not firing either, Preadjust or test is not working.
Door sensor and water pump switch are working.
Any help appreciated
