Hi there,
I'm just wondering about why the g-code below has been generated with regard to the toolpath? I ahve attched a screenshot of the toolpath.
In the pocketing screen in MadCam the top of the material is set at 0 and the bottom at -5. I move the tool to the corner of the material and zero coordinates in Mach3.
When the program starts, it moves to the center of the circle and plunges down, as I think is defined in the g-code below as z13.000. A circle is created, but the tool seems to plunge in first (way to deep) and then on ocassion do a cutting spirial where it is cutting air - it's like it's doing the toolpath in reverse.
I am relatively new to g-code and CNC, so someone more experienced may just be able to state the obvious - I am hoping so!
Cheers,
Hamish
Ocircle2
G40 G54 G80 G90
(HD cutter 1)
M06 T1
S4000 F350 M03
G43 H1
G00 X32.06526 Y30.50837
Z13.00000
G01 Z10.01267 F350
X31.80514 Y30.99461 Z9.91543 F350
X31.62843 Y31.17133 Z9.87137
X30.77736 Y31.62661 Z9.70118
X29.92630 Z9.55111
X29.07523 Y31.17132 Z9.38092
X28.89853 Y30.99461 Z9.33686
X28.44323 Y30.14355 Z9.16667
Y29.29249
X28.89853 Y28.44142
X29.07523 Y28.26471
X29.92630 Y27.80942
X30.77736
X31.62843 Y28.26471
X31.80514 Y28.44142
X32.26043 Y29.29249
Y30.14355
X31.80514 Y30.99461
X31.62843 Y31.17133
X30.77736 Y31.62661
X29.92630
X29.07523 Y31.17132
X28.89853 Y30.99461
X28.44323 Y30.14355
X26.99227 Y30.56908
X25.54131 Y30.99461
X25.40499 Y30.14355
Y29.29249
X25.54131 Y28.44142
X25.67098 Y28.06660
X25.86021 Y27.59036
X26.38199 Y26.73929
X26.52204 Y26.57526
X27.20907 Y25.88823
X27.37311 Y25.74817
X28.22417 Y25.22640
X28.70041 Y25.03717
X29.07523 Y24.90750
X29.92630 Y24.77118
X30.77736
X31.62843 Y24.90750
X32.00325 Y25.03717
X32.47949 Y25.22640
X33.33055 Y25.74817
X33.49459 Y25.88823
X34.18162 Y26.57526
X34.32167 Y26.73929
X34.84344 Y27.59036
X35.03268 Y28.06660
X35.16235 Y28.44142
X35.29866 Y29.29249
Y30.14355
X35.16235 Y30.99461
X35.03268 Y31.36944
X34.84344 Y31.84568
X34.32167 Y32.69674
X34.18162 Y32.86077
X33.49459 Y33.54781
X33.33055 Y33.68786
X32.47949 Y34.20963
X32.00325 Y34.39887
X31.62843 Y34.52854
X30.77736 Y34.66485
X29.92630
X29.07523 Y34.52854
X28.70041 Y34.39887
X28.22417 Y34.20964
X27.37311 Y33.68786
X27.20907 Y33.54781
X26.52204 Y32.86077
X26.38199 Y32.69674
X25.86021 Y31.84568
X25.67098 Y31.36944
X25.54131 Y30.99461
X24.09682 Y31.42015
X22.65234 Y31.84568
X22.48139 Y30.99461
X22.38634 Y30.14355
Y29.29249
X22.48139 Y28.44142
X22.65233 Y27.59036
X22.96124 Y26.73929
X23.11779 Y26.36845
X23.35484 Y25.88823
X23.89594 Y25.03717
X23.96885 Y24.94545
X24.61721 Y24.18610
X24.81991 Y23.98339
X25.57926 Y23.33504
X25.67098 Y23.26213
X26.52204 Y22.72102
X27.00226 Y22.48397
X27.37311 Y22.32743
X28.22417 Y22.01852
X29.07523 Y21.84758
X29.92630 Y21.75253
X30.77736
X31.62843 Y21.84758
X32.47949 Y22.01852
X33.33055 Y22.32743
X33.70140 Y22.48397
X34.18162 Y22.72102
X35.03268 Y23.26213
X35.12440 Y23.33504
X35.88374 Y23.98339
X36.08645 Y24.18610
X36.73481 Y24.94545
X36.80772 Y25.03717
X37.34883 Y25.88823
X37.58587 Y26.36845
X37.74242 Y26.73929
X38.05133 Y27.59036
X38.22227 Y28.44142
X38.31731 Y29.29249
Y30.14355
X38.22227 Y30.99461
X38.05132 Y31.84568
X37.74242 Y32.69674
X37.58587 Y33.06758
X37.34882 Y33.54781
X36.80772 Y34.39887
X36.73481 Y34.49058
X36.08646 Y35.24993
X35.88374 Y35.45265
X35.12439 Y36.10100
X35.03268 Y36.17391
X34.18162 Y36.71501
X33.70140 Y36.95206
X33.33055 Y37.10861
X32.47949 Y37.41751
X31.62843 Y37.58846
X30.77736 Y37.68350
X29.92630
X29.07523 Y37.58846
X28.22417 Y37.41751
X27.37311 Y37.10861
X27.00225 Y36.95206
X26.52204 Y36.71502
X25.67098 Y36.17391
X25.57926 Y36.10100
X24.81991 Y35.45264
X24.61721 Y35.24993
X23.96885 Y34.49058
X23.89594 Y34.39887
X23.35484 Y33.54781
X23.11779 Y33.06758
X22.96124 Y32.69674
X22.65234 Y31.84568
X21.18293 Y32.15258
X19.71353 Y32.45948
X19.57703 Y31.84568
X19.44609 Y30.99461
X19.37626 Y30.14355
Y29.29249
X19.44609 Y28.44142
X19.57703 Y27.59036
X19.71353 Y26.97655
X19.77269 Y26.73929
X20.06416 Y25.88823
X20.42342 Y25.03717
X20.56460 Y24.73623
X20.86721 Y24.18610
X21.41661 Y23.33504
X22.09319 Y22.48397
X22.26672 Y22.29394
X22.92776 Y21.63291
X23.11779 Y21.45938
X23.96885 Y20.78280
X24.81991 Y20.23340
X25.37004 Y19.93078
X25.67098 Y19.78961
X26.52204 Y19.43034
X27.37311 Y19.13888
X27.61036 Y19.07972
X28.22417 Y18.94322
X29.07523 Y18.81228
X29.92630 Y18.74245
X30.77736
X31.62843 Y18.81228
X32.47949 Y18.94322
X33.09329 Y19.07972
X33.33055 Y19.13888
X34.18162 Y19.43035
X35.03268 Y19.78961
X35.33361 Y19.93078
X35.88374 Y20.23340
X36.73481 Y20.78280
X37.58587 Y21.45938
X37.77590 Y21.63291
X38.43694 Y22.29394
X38.61047 Y22.48397
X39.28800 Y23.33628
X39.83645 Y24.18610
X40.13906 Y24.73623
X40.28024 Y25.03717
X40.63950 Y25.88823
X40.93097 Y26.73929
X40.99013 Y26.97655
X41.12662 Y27.59036
X41.25757 Y28.44142
X41.32740 Y29.29249
Y30.14355
X41.25757 Y30.99461
X41.12663 Y31.84568
X40.99013 Y32.45948
X40.93097 Y32.69674
X40.63950 Y33.54781
X40.28024 Y34.39887
X40.13906 Y34.69979
X39.83644 Y35.24993
X39.28704 Y36.10100
X38.61047 Y36.95206
X38.43694 Y37.14209
X37.77591 Y37.80312
X37.58587 Y37.97666
X36.73357 Y38.65419
X35.88374 Y39.20263
X35.33361 Y39.50525
X35.03268 Y39.64642
X34.18162 Y40.00569
X33.33055 Y40.29716
X33.09329 Y40.35632
X32.47949 Y40.49281
X31.62843 Y40.62376
X30.77736 Y40.69358
X29.92630
X29.07523 Y40.62376
X28.22417 Y40.49281
X27.61036 Y40.35632
X27.37311 Y40.29716
X26.52204 Y40.00569
X25.67098 Y39.64643
X25.37005 Y39.50525
X24.81991 Y39.20264
X23.96885 Y38.65324
X23.11779 Y37.97666
X22.92776 Y37.80312
X22.26672 Y37.14209
X22.09319 Y36.95206
X21.41566 Y36.09975
X20.86721 Y35.24993
X20.56460 Y34.69980
X20.42342 Y34.39887
X20.06416 Y33.54781
X19.77269 Y32.69674
X19.71353 Y32.45948
X18.30329 Y33.00364
X16.89304 Y33.54781
X16.68084 Y32.69674
X16.53072 Y31.84568
X16.42148 Y30.99461
X16.37099 Y30.14355
Y29.29249
X16.42148 Y28.44142
X16.53071 Y27.59036
X16.68084 Y26.73929
X16.89304 Y25.88823
X17.17558 Y25.03717
X17.50897 Y24.18610
X17.90822 Y23.33504
X18.01140 Y23.13315
X18.38566 Y22.48397
X18.86247 Y21.73985
X19.59329 Y20.78185
X19.71353 Y20.64098
X20.36207 Y19.93078
X20.56460 Y19.72826
X21.27479 Y19.07972
X21.41566 Y18.95948
X22.37366 Y18.22866
X23.11779 Y17.75185
X23.76696 Y17.37759
X23.96885 Y17.27440
X24.81991 Y16.87515
X25.71162 Y16.52653
X26.52204 Y16.25923
X27.37311 Y16.04703
X28.22417 Y15.89690
X29.07523 Y15.78767
X29.92630 Y15.73717
X30.77736
X31.62843 Y15.78767
X32.47949 Y15.89690
X33.33055 Y16.04703
X34.18162 Y16.25923
X35.03268 Y16.54176
X35.88374 Y16.87515
X36.73481 Y17.27440
X36.93670 Y17.37759
X37.58587 Y17.75185
X38.33000 Y18.22866
X39.28800 Y18.95947
X39.42887 Y19.07972
X40.13906 Y19.72826
X40.34159 Y19.93078
X40.99013 Y20.64098
X41.11037 Y20.78185
X41.84119 Y21.73985
X42.31800 Y22.48397
X42.69226 Y23.13316
X42.79544 Y23.33504
X43.19469 Y24.18610
X43.54332 Y25.07780
X43.81062 Y25.88823
X44.02281 Y26.73929
X44.17294 Y27.59036
X44.28218 Y28.44142
X44.33267 Y29.29249
Y30.14355
X44.28218 Y30.99461
X44.17294 Y31.84568
X44.02282 Y32.69674
X43.81062 Y33.54781
X43.52808 Y34.39887
X43.19469 Y35.24993
X42.79544 Y36.10100
X42.69226 Y36.30287
X42.31799 Y36.95206
X41.84119 Y37.69619
X41.11037 Y38.65419
X40.99013 Y38.79506
X40.34159 Y39.50525
X40.13906 Y39.70778
X39.42887 Y40.35632
X39.28800 Y40.47656
X38.33000 Y41.20738
X37.58587 Y41.68418
X36.93668 Y42.05844
X36.73481 Y42.16163
X35.88374 Y42.56088
X34.99204 Y42.90951
X34.18162 Y43.17680
X33.33055 Y43.38900
X32.47949 Y43.53913
X31.62843 Y43.64837
X30.77736 Y43.69886
X29.92630
X29.07523 Y43.64837
X28.22417 Y43.53913
X27.37311 Y43.38900
X26.52204 Y43.17681
X25.67098 Y42.89427
X24.81991 Y42.56088
X23.96885 Y42.16163
X23.76697 Y42.05844
X23.11779 Y41.68419
X22.37366 Y41.20738
X21.41566 Y40.47656
X21.27479 Y40.35632
X20.56460 Y39.70778
X20.36207 Y39.50525
X19.71353 Y38.79506
X19.59329 Y38.65419
X18.86247 Y37.69619
X18.38566 Y36.95206
X18.01140 Y36.30288
X17.90822 Y36.10100
X17.50897 Y35.24993
X17.16034 Y34.35823
X16.89304 Y33.54781
X15.46228 Y34.00869
X14.03151 Y34.46957
X13.72725 Y33.26149
X13.51590 Y32.06058
X13.39312 Y30.87617
X13.35358 Y29.71796
X13.39134 Y28.55968
X13.51405 Y27.37514
X13.72533 Y26.17406
X14.02956 Y24.96581
X14.42981 Y23.76073
X14.92769 Y22.56988
X15.52310 Y21.40485
X16.21415 Y20.27736
X16.99707 Y19.19897
X17.86628 Y18.18064
X18.81446 Y17.23247
X19.83278 Y16.36326
X20.91117 Y15.58034
X22.03866 Y14.88929
X23.20369 Y14.29388
X24.39454 Y13.79600
X25.59963 Y13.39575
X26.80787 Y13.09152
X28.00895 Y12.88024
X29.19349 Y12.75753
X30.35183 Y12.71802
X31.51017 Y12.75753
X32.69471 Y12.88024
X33.89579 Y13.09152
X35.10403 Y13.39575
X36.30913 Y13.79600
X37.49996 Y14.29387
X38.66499 Y14.88929
X39.79248 Y15.58034
X40.87089 Y16.36326
X41.88920 Y17.23247
X42.83739 Y18.18064
X43.70482 Y19.20047
X44.48766 Y20.27871
X45.17864 Y21.40602
X45.77402 Y22.57088
X46.27189 Y23.76155
X46.67215 Y24.96646
X46.97641 Y26.17454
X47.18776 Y27.37547
X47.31054 Y28.55986
X47.35008 Y29.71807
X47.31052 Y30.87630
X47.18774 Y32.06070
X46.97638 Y33.26163
X46.67211 Y34.46973
X46.27183 Y35.67464
X45.77395 Y36.86531
X45.17856 Y38.03016
X44.48756 Y39.15748
X43.70471 Y40.23571
X42.83561 Y41.25389
X41.88756 Y42.20193
X40.86938 Y43.07101
X39.79115 Y43.85384
X38.66382 Y44.54483
X37.49896 Y45.14021
X36.30830 Y45.63808
X35.10339 Y46.03834
X33.89530 Y46.34260
X32.69439 Y46.55395
X31.50999 Y46.67672
X30.35177 Y46.71627
X29.19356 Y46.67671
X28.00914 Y46.55392
X26.80821 Y46.34257
X25.60013 Y46.03830
X24.39521 Y45.63802
X23.20454 Y45.14014
X22.03968 Y44.54475
X20.91237 Y43.85375
X19.83414 Y43.07090
X18.81597 Y42.20180
X17.86793 Y41.25375
X16.99883 Y40.23557
X16.21600 Y39.15733
X15.52501 Y38.03001
X14.92964 Y36.86515
X14.43178 Y35.67449
X14.03151 Y34.46957
G00 Z13.00000
Z12.17933
G01 Z9.17933 F350
X31.80514 Y30.99461 Z9.08210 F350
X31.62843 Y31.17133 Z9.03803
X30.77736 Y31.62661 Z8.86784
X29.92630 Z8.71778
X29.07523 Y31.17132 Z8.54759
X28.89853 Y30.99461 Z8.50352
X28.44323 Y30.14355 Z8.33333
Y29.29249
X28.89853 Y28.44142
X29.07523 Y28.26471
X29.92630 Y27.80942
X30.77736
X31.62843 Y28.26471
X31.80514 Y28.44142
X32.26043 Y29.29249
Y30.14355
X31.80514 Y30.99461
X31.62843 Y31.17133
X30.77736 Y31.62661
X29.92630
X29.07523 Y31.17132
X28.89853 Y30.99461
X28.44323 Y30.14355
X26.99227 Y30.56908
X25.54131 Y30.99461
X25.40499 Y30.14355
Y29.29249
X25.54131 Y28.44142
X25.67098 Y28.06660
X25.86021 Y27.59036
X26.38199 Y26.73929
X26.52204 Y26.57526
X27.20907 Y25.88823
X27.37311 Y25.74817
X28.22417 Y25.22640
X28.70041 Y25.03717
X29.07523 Y24.90750
X29.92630 Y24.77118
X30.77736
X31.62843 Y24.90750
X32.00325 Y25.03717
X32.47949 Y25.22640
X33.33055 Y25.74817
X33.49459 Y25.88823
X34.18162 Y26.57526
X34.32167 Y26.73929
X34.84344 Y27.59036
X35.03268 Y28.06660
X35.16235 Y28.44142
X35.29866 Y29.29249
Y30.14355
X35.16235 Y30.99461
X35.03268 Y31.36944
X34.84344 Y31.84568
X34.32167 Y32.69674
X34.18162 Y32.86077
X33.49459 Y33.54781
X33.33055 Y33.68786
X32.47949 Y34.20963
X32.00325 Y34.39887
X31.62843 Y34.52854
X30.77736 Y34.66485
X29.92630
X29.07523 Y34.52854
X28.70041 Y34.39887
X28.22417 Y34.20964
X27.37311 Y33.68786
X27.20907 Y33.54781
X26.52204 Y32.86077
X26.38199 Y32.69674
X25.86021 Y31.84568
X25.67098 Y31.36944
X25.54131 Y30.99461
X24.09682 Y31.42015
X22.65234 Y31.84568
X22.48139 Y30.99461
X22.38634 Y30.14355
Y29.29249
X22.48139 Y28.44142
X22.65233 Y27.59036
X22.96124 Y26.73929
X23.11779 Y26.36845
X23.35484 Y25.88823
X23.89594 Y25.03717
X23.96885 Y24.94545
X24.61721 Y24.18610
X24.81991 Y23.98339
X25.57926 Y23.33504
X25.67098 Y23.26213
X26.52204 Y22.72102
X27.00226 Y22.48397
X27.37311 Y22.32743
X28.22417 Y22.01852
X29.07523 Y21.84758
X29.92630 Y21.75253
X30.77736
X31.62843 Y21.84758
X32.47949 Y22.01852
X33.33055 Y22.32743
X33.70140 Y22.48397
X34.18162 Y22.72102
X35.03268 Y23.26213
X35.12440 Y23.33504
X35.88374 Y23.98339
X36.08645 Y24.18610
X36.73481 Y24.94545
X36.80772 Y25.03717
X37.34883 Y25.88823
X37.58587 Y26.36845
X37.74242 Y26.73929
X38.05133 Y27.59036
X38.22227 Y28.44142
X38.31731 Y29.29249
Y30.14355
X38.22227 Y30.99461
X38.05132 Y31.84568
X37.74242 Y32.69674
X37.58587 Y33.06758
X37.34882 Y33.54781
X36.80772 Y34.39887
X36.73481 Y34.49058
X36.08646 Y35.24993
X35.88374 Y35.45265
X35.12439 Y36.10100
X35.03268 Y36.17391
X34.18162 Y36.71501
X33.70140 Y36.95206
X33.33055 Y37.10861
X32.47949 Y37.41751
X31.62843 Y37.58846
X30.77736 Y37.68350
X29.92630
X29.07523 Y37.58846
X28.22417 Y37.41751
X27.37311 Y37.10861
X27.00225 Y36.95206
X26.52204 Y36.71502
X25.67098 Y36.17391
X25.57926 Y36.10100
X24.81991 Y35.45264
X24.61721 Y35.24993
X23.96885 Y34.49058
X23.89594 Y34.39887
X23.35484 Y33.54781
X23.11779 Y33.06758
X22.96124 Y32.69674
X22.65234 Y31.84568
X21.18293 Y32.15258
X19.71353 Y32.45948
X19.57703 Y31.84568
X19.44609 Y30.99461
X19.37626 Y30.14355
Y29.29249
X19.44609 Y28.44142
X19.57703 Y27.59036
X19.71353 Y26.97655
X19.77269 Y26.73929
X20.06416 Y25.88823
X20.42342 Y25.03717
X20.56460 Y24.73623
X20.86721 Y24.18610
X21.41661 Y23.33504
X22.09319 Y22.48397
X22.26672 Y22.29394
X22.92776 Y21.63291
X23.11779 Y21.45938
X23.96885 Y20.78280
X24.81991 Y20.23340
X25.37004 Y19.93078
X25.67098 Y19.78961
X26.52204 Y19.43034
X27.37311 Y19.13888
X27.61036 Y19.07972
X28.22417 Y18.94322
X29.07523 Y18.81228
X29.92630 Y18.74245
X30.77736
X31.62843 Y18.81228
X32.47949 Y18.94322
X33.09329 Y19.07972
X33.33055 Y19.13888
X34.18162 Y19.43035
X35.03268 Y19.78961
X35.33361 Y19.93078
X35.88374 Y20.23340
X36.73481 Y20.78280
X37.58587 Y21.45938
X37.77590 Y21.63291
X38.43694 Y22.29394
X38.61047 Y22.48397
X39.28800 Y23.33628
X39.83645 Y24.18610
X40.13906 Y24.73623
X40.28024 Y25.03717
X40.63950 Y25.88823
X40.93097 Y26.73929
X40.99013 Y26.97655
X41.12662 Y27.59036
X41.25757 Y28.44142
X41.32740 Y29.29249
Y30.14355
X41.25757 Y30.99461
X41.12663 Y31.84568
X40.99013 Y32.45948
X40.93097 Y32.69674
X40.63950 Y33.54781
X40.28024 Y34.39887
X40.13906 Y34.69979
X39.83644 Y35.24993
X39.28704 Y36.10100
X38.61047 Y36.95206
X38.43694 Y37.14209
X37.77591 Y37.80312
X37.58587 Y37.97666
X36.73357 Y38.65419
X35.88374 Y39.20263
X35.33361 Y39.50525
X35.03268 Y39.64642
X34.18162 Y40.00569
X33.33055 Y40.29716
X33.09329 Y40.35632
X32.47949 Y40.49281
X31.62843 Y40.62376
X30.77736 Y40.69358
X29.92630
X29.07523 Y40.62376
X28.22417 Y40.49281
X27.61036 Y40.35632
X27.37311 Y40.29716
X26.52204 Y40.00569
X25.67098 Y39.64643
X25.37005 Y39.50525
X24.81991 Y39.20264
X23.96885 Y38.65324
X23.11779 Y37.97666
X22.92776 Y37.80312
X22.26672 Y37.14209
X22.09319 Y36.95206
X21.41566 Y36.09975
X20.86721 Y35.24993
X20.56460 Y34.69980
X20.42342 Y34.39887
X20.06416 Y33.54781
X19.77269 Y32.69674
X19.71353 Y32.45948
X18.30329 Y33.00364
X16.89304 Y33.54781
X16.68084 Y32.69674
X16.53072 Y31.84568
X16.42148 Y30.99461
X16.37099 Y30.14355
Y29.29249
X16.42148 Y28.44142
X16.53071 Y27.59036
X16.68084 Y26.73929
X16.89304 Y25.88823
X17.17558 Y25.03717
X17.50897 Y24.18610
X17.90822 Y23.33504
X18.01140 Y23.13315
X18.38566 Y22.48397
X18.86247 Y21.73985
X19.59329 Y20.78185
X19.71353 Y20.64098
X20.36207 Y19.93078
X20.56460 Y19.72826
X21.27479 Y19.07972
X21.41566 Y18.95948
X22.37366 Y18.22866
X23.11779 Y17.75185
X23.76696 Y17.37759
X23.96885 Y17.27440
X24.81991 Y16.87515
X25.71162 Y16.52653
X26.52204 Y16.25923
X27.37311 Y16.04703
X28.22417 Y15.89690
X29.07523 Y15.78767
X29.92630 Y15.73717
X30.77736
X31.62843 Y15.78767
X32.47949 Y15.89690
X33.33055 Y16.04703
X34.18162 Y16.25923
X35.03268 Y16.54176
X35.88374 Y16.87515
X36.73481 Y17.27440
X36.93670 Y17.37759
X37.58587 Y17.75185
X38.33000 Y18.22866
X39.28800 Y18.95947
X39.42887 Y19.07972
X40.13906 Y19.72826
X40.34159 Y19.93078
X40.99013 Y20.64098
X41.11037 Y20.78185
X41.84119 Y21.73985
X42.31800 Y22.48397
X42.69226 Y23.13316
X42.79544 Y23.33504
X43.19469 Y24.18610
X43.54332 Y25.07780
X43.81062 Y25.88823
X44.02281 Y26.73929
X44.17294 Y27.59036
X44.28218 Y28.44142
X44.33267 Y29.29249
Y30.14355
X44.28218 Y30.99461
X44.17294 Y31.84568
X44.02282 Y32.69674
X43.81062 Y33.54781
X43.52808 Y34.39887
X43.19469 Y35.24993
X42.79544 Y36.10100
X42.69226 Y36.30287
X42.31799 Y36.95206
X41.84119 Y37.69619
X41.11037 Y38.65419
X40.99013 Y38.79506
X40.34159 Y39.50525
X40.13906 Y39.70778
X39.42887 Y40.35632
X39.28800 Y40.47656
X38.33000 Y41.20738
X37.58587 Y41.68418
X36.93668 Y42.05844
X36.73481 Y42.16163
X35.88374 Y42.56088
X34.99204 Y42.90951
X34.18162 Y43.17680
X33.33055 Y43.38900
X32.47949 Y43.53913
X31.62843 Y43.64837
X30.77736 Y43.69886
X29.92630
X29.07523 Y43.64837
X28.22417 Y43.53913
X27.37311 Y43.38900
X26.52204 Y43.17681
X25.67098 Y42.89427
X24.81991 Y42.56088
X23.96885 Y42.16163
X23.76697 Y42.05844
X23.11779 Y41.68419
X22.37366 Y41.20738
X21.41566 Y40.47656
X21.27479 Y40.35632
X20.56460 Y39.70778
X20.36207 Y39.50525
X19.71353 Y38.79506
X19.59329 Y38.65419
X18.86247 Y37.69619
X18.38566 Y36.95206
X18.01140 Y36.30288
X17.90822 Y36.10100
X17.50897 Y35.24993
X17.16034 Y34.35823
X16.89304 Y33.54781
X15.46228 Y34.00869
X14.03151 Y34.46957
X13.72725 Y33.26149
X13.51590 Y32.06058
X13.39312 Y30.87617
X13.35358 Y29.71796
X13.39134 Y28.55968
X13.51405 Y27.37514
X13.72533 Y26.17406
X14.02956 Y24.96581
X14.42981 Y23.76073
X14.92769 Y22.56988
X15.52310 Y21.40485
X16.21415 Y20.27736
X16.99707 Y19.19897
X17.86628 Y18.18064
X18.81446 Y17.23247
X19.83278 Y16.36326
X20.91117 Y15.58034
X22.03866 Y14.88929
X23.20369 Y14.29388
X24.39454 Y13.79600
X25.59963 Y13.39575
X26.80787 Y13.09152
X28.00895 Y12.88024
X29.19349 Y12.75753
X30.35183 Y12.71802
X31.51017 Y12.75753
X32.69471 Y12.88024
X33.89579 Y13.09152
X35.10403 Y13.39575
X36.30913 Y13.79600
X37.49996 Y14.29387
X38.66499 Y14.88929
X39.79248 Y15.58034
X40.87089 Y16.36326
X41.88920 Y17.23247
X42.83739 Y18.18064
X43.70482 Y19.20047
X44.48766 Y20.27871
X45.17864 Y21.40602
X45.77402 Y22.57088
X46.27189 Y23.76155
X46.67215 Y24.96646
X46.97641 Y26.17454
X47.18776 Y27.37547
X47.31054 Y28.55986
X47.35008 Y29.71807
X47.31052 Y30.87630
X47.18774 Y32.06070
X46.97638 Y33.26163
X46.67211 Y34.46973
X46.27183 Y35.67464
X45.77395 Y36.86531
X45.17856 Y38.03016
X44.48756 Y39.15748
X43.70471 Y40.23571
X42.83561 Y41.25389
X41.88756 Y42.20193
X40.86938 Y43.07101
X39.79115 Y43.85384
X38.66382 Y44.54483
X37.49896 Y45.14021
X36.30830 Y45.63808
X35.10339 Y46.03834
X33.89530 Y46.34260
X32.69439 Y46.55395
X31.50999 Y46.67672
X30.35177 Y46.71627
X29.19356 Y46.67671
X28.00914 Y46.55392
X26.80821 Y46.34257
X25.60013 Y46.03830
X24.39521 Y45.63802
X23.20454 Y45.14014
X22.03968 Y44.54475
X20.91237 Y43.85375
X19.83414 Y43.07090
X18.81597 Y42.20180
X17.86793 Y41.25375
X16.99883 Y40.23557
X16.21600 Y39.15733
X15.52501 Y38.03001
X14.92964 Y36.86515
X14.43178 Y35.67449
X14.03151 Y34.46957
G00 Z13.00000
Z11.34600
G01 Z8.34600 F350
X31.80514 Y30.99461 Z8.24877 F350
X31.62843 Y31.17133 Z8.20470
X30.77736 Y31.62661 Z8.03451
X29.92630 Z7.88445
X29.07523 Y31.17132 Z7.71426
X28.89853 Y30.99461 Z7.67019
X28.44323 Y30.14355 Z7.50000
Y29.29249
X28.89853 Y28.44142
X29.07523 Y28.26471
X29.92630 Y27.80942
X30.77736
X31.62843 Y28.26471
X31.80514 Y28.44142
X32.26043 Y29.29249
Y30.14355
X31.80514 Y30.99461
X31.62843 Y31.17133
X30.77736 Y31.62661
X29.92630
X29.07523 Y31.17132
X28.89853 Y30.99461
X28.44323 Y30.14355
X26.99227 Y30.56908
X25.54131 Y30.99461
X25.40499 Y30.14355
Y29.29249
X25.54131 Y28.44142
X25.67098 Y28.06660
X25.86021 Y27.59036
X26.38199 Y26.73929
X26.52204 Y26.57526
X27.20907 Y25.88823
X27.37311 Y25.74817
X28.22417 Y25.22640
X28.70041 Y25.03717
X29.07523 Y24.90750
X29.92630 Y24.77118
X30.77736
X31.62843 Y24.90750
X32.00325 Y25.03717
X32.47949 Y25.22640
X33.33055 Y25.74817
X33.49459 Y25.88823
X34.18162 Y26.57526
X34.32167 Y26.73929
X34.84344 Y27.59036
X35.03268 Y28.06660
X35.16235 Y28.44142
X35.29866 Y29.29249
Y30.14355
X35.16235 Y30.99461
X35.03268 Y31.36944
X34.84344 Y31.84568
X34.32167 Y32.69674
X34.18162 Y32.86077
X33.49459 Y33.54781
X33.33055 Y33.68786
X32.47949 Y34.20963
X32.00325 Y34.39887
X31.62843 Y34.52854
X30.77736 Y34.66485
X29.92630
X29.07523 Y34.52854
X28.70041 Y34.39887
X28.22417 Y34.20964
X27.37311 Y33.68786
X27.20907 Y33.54781
X26.52204 Y32.86077
X26.38199 Y32.69674
X25.86021 Y31.84568
X25.67098 Y31.36944
X25.54131 Y30.99461
X24.09682 Y31.42015
X22.65234 Y31.84568
X22.48139 Y30.99461
X22.38634 Y30.14355
Y29.29249
X22.48139 Y28.44142
X22.65233 Y27.59036
X22.96124 Y26.73929
X23.11779 Y26.36845
X23.35484 Y25.88823
X23.89594 Y25.03717
X23.96885 Y24.94545
X24.61721 Y24.18610
X24.81991 Y23.98339
X25.57926 Y23.33504
X25.67098 Y23.26213
X26.52204 Y22.72102
X27.00226 Y22.48397
X27.37311 Y22.32743
X28.22417 Y22.01852
X29.07523 Y21.84758
X29.92630 Y21.75253
X30.77736
X31.62843 Y21.84758
X32.47949 Y22.01852
X33.33055 Y22.32743
X33.70140 Y22.48397
X34.18162 Y22.72102
X35.03268 Y23.26213
X35.12440 Y23.33504
X35.88374 Y23.98339
X36.08645 Y24.18610
X36.73481 Y24.94545
X36.80772 Y25.03717
X37.34883 Y25.88823
X37.58587 Y26.36845
X37.74242 Y26.73929
X38.05133 Y27.59036
X38.22227 Y28.44142
X38.31731 Y29.29249
Y30.14355
X38.22227 Y30.99461
X38.05132 Y31.84568
X37.74242 Y32.69674
X37.58587 Y33.06758
X37.34882 Y33.54781
X36.80772 Y34.39887
X36.73481 Y34.49058
X36.08646 Y35.24993
X35.88374 Y35.45265
X35.12439 Y36.10100
X35.03268 Y36.17391
X34.18162 Y36.71501
X33.70140 Y36.95206
X33.33055 Y37.10861
X32.47949 Y37.41751
X31.62843 Y37.58846
X30.77736 Y37.68350
X29.92630
X29.07523 Y37.58846
X28.22417 Y37.41751
X27.37311 Y37.10861
X27.00225 Y36.95206
X26.52204 Y36.71502
X25.67098 Y36.17391
X25.57926 Y36.10100
X24.81991 Y35.45264
X24.61721 Y35.24993
X23.96885 Y34.49058
X23.89594 Y34.39887
X23.35484 Y33.54781
X23.11779 Y33.06758
X22.96124 Y32.69674
X22.65234 Y31.84568
X21.18293 Y32.15258
X19.71353 Y32.45948
X19.57703 Y31.84568
X19.44609 Y30.99461
X19.37626 Y30.14355
Y29.29249
X19.44609 Y28.44142
X19.57703 Y27.59036
X19.71353 Y26.97655
X19.77269 Y26.73929
X20.06416 Y25.88823
X20.42342 Y25.03717
X20.56460 Y24.73623
X20.86721 Y24.18610
X21.41661 Y23.33504
X22.09319 Y22.48397
X22.26672 Y22.29394
X22.92776 Y21.63291
X23.11779 Y21.45938
X23.96885 Y20.78280
X24.81991 Y20.23340
X25.37004 Y19.93078
X25.67098 Y19.78961
X26.52204 Y19.43034
X27.37311 Y19.13888
X27.61036 Y19.07972
X28.22417 Y18.94322
X29.07523 Y18.81228
X29.92630 Y18.74245
X30.77736
X31.62843 Y18.81228
X32.47949 Y18.94322
X33.09329 Y19.07972
X33.33055 Y19.13888
X34.18162 Y19.43035
X35.03268 Y19.78961
X35.33361 Y19.93078
X35.88374 Y20.23340
X36.73481 Y20.78280
X37.58587 Y21.45938
X37.77590 Y21.63291
X38.43694 Y22.29394
X38.61047 Y22.48397
X39.28800 Y23.33628
X39.83645 Y24.18610
X40.13906 Y24.73623
X40.28024 Y25.03717
X40.63950 Y25.88823
X40.93097 Y26.73929
X40.99013 Y26.97655
X41.12662 Y27.59036
X41.25757 Y28.44142
X41.32740 Y29.29249
Y30.14355
X41.25757 Y30.99461
X41.12663 Y31.84568
X40.99013 Y32.45948
X40.93097 Y32.69674
X40.63950 Y33.54781
X40.28024 Y34.39887
X40.13906 Y34.69979
X39.83644 Y35.24993
X39.28704 Y36.10100
X38.61047 Y36.95206
X38.43694 Y37.14209
X37.77591 Y37.80312
X37.58587 Y37.97666
X36.73357 Y38.65419
X35.88374 Y39.20263
X35.33361 Y39.50525
X35.03268 Y39.64642
X34.18162 Y40.00569
X33.33055 Y40.29716
X33.09329 Y40.35632
X32.47949 Y40.49281
X31.62843 Y40.62376
X30.77736 Y40.69358
X29.92630
X29.07523 Y40.62376
X28.22417 Y40.49281
X27.61036 Y40.35632
X27.37311 Y40.29716
X26.52204 Y40.00569
X25.67098 Y39.64643
X25.37005 Y39.50525
X24.81991 Y39.20264
X23.96885 Y38.65324
X23.11779 Y37.97666
X22.92776 Y37.80312
X22.26672 Y37.14209
X22.09319 Y36.95206
X21.41566 Y36.09975
X20.86721 Y35.24993
X20.56460 Y34.69980
X20.42342 Y34.39887
X20.06416 Y33.54781
X19.77269 Y32.69674
X19.71353 Y32.45948
X18.30329 Y33.00364
X16.89304 Y33.54781
X16.68084 Y32.69674
X16.53072 Y31.84568
X16.42148 Y30.99461
X16.37099 Y30.14355
Y29.29249
X16.42148 Y28.44142
X16.53071 Y27.59036
X16.68084 Y26.73929
X16.89304 Y25.88823
X17.17558 Y25.03717
X17.50897 Y24.18610
X17.90822 Y23.33504
X18.01140 Y23.13315
X18.38566 Y22.48397
X18.86247 Y21.73985
X19.59329 Y20.78185
X19.71353 Y20.64098
X20.36207 Y19.93078
X20.56460 Y19.72826
X21.27479 Y19.07972
X21.41566 Y18.95948
X22.37366 Y18.22866
X23.11779 Y17.75185
X23.76696 Y17.37759
X23.96885 Y17.27440
X24.81991 Y16.87515
X25.71162 Y16.52653
X26.52204 Y16.25923
X27.37311 Y16.04703
X28.22417 Y15.89690
X29.07523 Y15.78767
X29.92630 Y15.73717
X30.77736
X31.62843 Y15.78767
X32.47949 Y15.89690
X33.33055 Y16.04703
X34.18162 Y16.25923
X35.03268 Y16.54176
X35.88374 Y16.87515
X36.73481 Y17.27440
X36.93670 Y17.37759
X37.58587 Y17.75185
X38.33000 Y18.22866
X39.28800 Y18.95947
X39.42887 Y19.07972
X40.13906 Y19.72826
X40.34159 Y19.93078
X40.99013 Y20.64098
X41.11037 Y20.78185
X41.84119 Y21.73985
X42.31800 Y22.48397
X42.69226 Y23.13316
X42.79544 Y23.33504
X43.19469 Y24.18610
X43.54332 Y25.07780
X43.81062 Y25.88823
X44.02281 Y26.73929
X44.17294 Y27.59036
X44.28218 Y28.44142
X44.33267 Y29.29249
Y30.14355
X44.28218 Y30.99461
X44.17294 Y31.84568
X44.02282 Y32.69674
X43.81062 Y33.54781
X43.52808 Y34.39887
X43.19469 Y35.24993
X42.79544 Y36.10100
X42.69226 Y36.30287
X42.31799 Y36.95206
X41.84119 Y37.69619
X41.11037 Y38.65419
X40.99013 Y38.79506
X40.34159 Y39.50525
X40.13906 Y39.70778
X39.42887 Y40.35632
X39.28800 Y40.47656
X38.33000 Y41.20738
X37.58587 Y41.68418
X36.93668 Y42.05844
X36.73481 Y42.16163
X35.88374 Y42.56088
X34.99204 Y42.90951
X34.18162 Y43.17680
X33.33055 Y43.38900
X32.47949 Y43.53913
X31.62843 Y43.64837
X30.77736 Y43.69886
X29.92630
X29.07523 Y43.64837
X28.22417 Y43.53913
X27.37311 Y43.38900
X26.52204 Y43.17681
X25.67098 Y42.89427
X24.81991 Y42.56088
X23.96885 Y42.16163
X23.76697 Y42.05844
X23.11779 Y41.68419
X22.37366 Y41.20738
X21.41566 Y40.47656
X21.27479 Y40.35632
X20.56460 Y39.70778
X20.36207 Y39.50525
X19.71353 Y38.79506
X19.59329 Y38.65419
X18.86247 Y37.69619
X18.38566 Y36.95206
X18.01140 Y36.30288
X17.90822 Y36.10100
X17.50897 Y35.24993
X17.16034 Y34.35823
X16.89304 Y33.54781
X15.46228 Y34.00869
X14.03151 Y34.46957
X13.72725 Y33.26149
X13.51590 Y32.06058
X13.39312 Y30.87617
X13.35358 Y29.71796
X13.39134 Y28.55968
X13.51405 Y27.37514
X13.72533 Y26.17406
X14.02956 Y24.96581
X14.42981 Y23.76073
X14.92769 Y22.56988
X15.52310 Y21.40485
X16.21415 Y20.27736
X16.99707 Y19.19897
X17.86628 Y18.18064
X18.81446 Y17.23247
X19.83278 Y16.36326
X20.91117 Y15.58034
X22.03866 Y14.88929
X23.20369 Y14.29388
X24.39454 Y13.79600
X25.59963 Y13.39575
X26.80787 Y13.09152
X28.00895 Y12.88024
X29.19349 Y12.75753
X30.35183 Y12.71802
X31.51017 Y12.75753
X32.69471 Y12.88024
X33.89579 Y13.09152
X35.10403 Y13.39575
X36.30913 Y13.79600
X37.49996 Y14.29387
X38.66499 Y14.88929
X39.79248 Y15.58034
X40.87089 Y16.36326
X41.88920 Y17.23247
X42.83739 Y18.18064
X43.70482 Y19.20047
X44.48766 Y20.27871
X45.17864 Y21.40602
X45.77402 Y22.57088
X46.27189 Y23.76155
X46.67215 Y24.96646
X46.97641 Y26.17454
X47.18776 Y27.37547
X47.31054 Y28.55986
X47.35008 Y29.71807
X47.31052 Y30.87630
X47.18774 Y32.06070
X46.97638 Y33.26163
X46.67211 Y34.46973
X46.27183 Y35.67464
X45.77395 Y36.86531
X45.17856 Y38.03016
X44.48756 Y39.15748
X43.70471 Y40.23571
X42.83561 Y41.25389
X41.88756 Y42.20193
X40.86938 Y43.07101
X39.79115 Y43.85384
X38.66382 Y44.54483
X37.49896 Y45.14021
X36.30830 Y45.63808
X35.10339 Y46.03834
X33.89530 Y46.34260
X32.69439 Y46.55395
X31.50999 Y46.67672
X30.35177 Y46.71627
X29.19356 Y46.67671
X28.00914 Y46.55392
X26.80821 Y46.34257
X25.60013 Y46.03830
X24.39521 Y45.63802
X23.20454 Y45.14014
X22.03968 Y44.54475
X20.91237 Y43.85375
X19.83414 Y43.07090
X18.81597 Y42.20180
X17.86793 Y41.25375
X16.99883 Y40.23557
X16.21600 Y39.15733
X15.52501 Y38.03001
X14.92964 Y36.86515
X14.43178 Y35.67449
X14.03151 Y34.46957
G00 Z13.00000
Z10.51267
G01 Z7.51267 F350
X31.80514 Y30.99461 Z7.41543 F350
X31.62843 Y31.17133 Z7.37137
X30.77736 Y31.62661 Z7.20118
X29.92630 Z7.05111
X29.07523 Y31.17132 Z6.88092
X28.89853 Y30.99461 Z6.83686
X28.44323 Y30.14355 Z6.66667
Y29.29249
X28.89853 Y28.44142
X29.07523 Y28.26471
X29.92630 Y27.80942
X30.77736
X31.62843 Y28.26471
X31.80514 Y28.44142
X32.26043 Y29.29249
Y30.14355
X31.80514 Y30.99461
X31.62843 Y31.17133
X30.77736 Y31.62661
X29.92630
X29.07523 Y31.17132
X28.89853 Y30.99461
X28.44323 Y30.14355
X26.99227 Y30.56908
X25.54131 Y30.99461
X25.40499 Y30.14355
Y29.29249
X25.54131 Y28.44142
X25.67098 Y28.06660
X25.86021 Y27.59036
X26.38199 Y26.73929
X26.52204 Y26.57526
X27.20907 Y25.88823
X27.37311 Y25.74817
X28.22417 Y25.22640
X28.70041 Y25.03717
X29.07523 Y24.90750
X29.92630 Y24.77118
X30.77736
X31.62843 Y24.90750
X32.00325 Y25.03717
X32.47949 Y25.22640
X33.33055 Y25.74817
X33.49459 Y25.88823
X34.18162 Y26.57526
X34.32167 Y26.73929
X34.84344 Y27.59036
X35.03268 Y28.06660
X35.16235 Y28.44142
X35.29866 Y29.29249
Y30.14355
X35.16235 Y30.99461
X35.03268 Y31.36944
X34.84344 Y31.84568
X34.32167 Y32.69674
X34.18162 Y32.86077
X33.49459 Y33.54781
X33.33055 Y33.68786
X32.47949 Y34.20963
X32.00325 Y34.39887
X31.62843 Y34.52854
X30.77736 Y34.66485
X29.92630
X29.07523 Y34.52854
X28.70041 Y34.39887
X28.22417 Y34.20964
X27.37311 Y33.68786
X27.20907 Y33.54781
X26.52204 Y32.86077
X26.38199 Y32.69674
X25.86021 Y31.84568
X25.67098 Y31.36944
X25.54131 Y30.99461
X24.09682 Y31.42015
X22.65234 Y31.84568
X22.48139 Y30.99461
X22.38634 Y30.14355
Y29.29249
X22.48139 Y28.44142
X22.65233 Y27.59036
X22.96124 Y26.73929
X23.11779 Y26.36845
X23.35484 Y25.88823
X23.89594 Y25.03717
X23.96885 Y24.94545
X24.61721 Y24.18610
X24.81991 Y23.98339
X25.57926 Y23.33504
X25.67098 Y23.26213
X26.52204 Y22.72102
X27.00226 Y22.48397
X27.37311 Y22.32743
X28.22417 Y22.01852
X29.07523 Y21.84758
X29.92630 Y21.75253
X30.77736
X31.62843 Y21.84758
X32.47949 Y22.01852
X33.33055 Y22.32743
X33.70140 Y22.48397
X34.18162 Y22.72102
X35.03268 Y23.26213
X35.12440 Y23.33504
X35.88374 Y23.98339
X36.08645 Y24.18610
X36.73481 Y24.94545
X36.80772 Y25.03717
X37.34883 Y25.88823
X37.58587 Y26.36845
X37.74242 Y26.73929
X38.05133 Y27.59036
X38.22227 Y28.44142
X38.31731 Y29.29249
Y30.14355
X38.22227 Y30.99461
X38.05132 Y31.84568
X37.74242 Y32.69674
X37.58587 Y33.06758
X37.34882 Y33.54781
X36.80772 Y34.39887
X36.73481 Y34.49058
X36.08646 Y35.24993
X35.88374 Y35.45265
X35.12439 Y36.10100
X35.03268 Y36.17391
X34.18162 Y36.71501
X33.70140 Y36.95206
X33.33055 Y37.10861
X32.47949 Y37.41751
X31.62843 Y37.58846
X30.77736 Y37.68350
X29.92630
X29.07523 Y37.58846
X28.22417 Y37.41751
X27.37311 Y37.10861
X27.00225 Y36.95206
X26.52204 Y36.71502
X25.67098 Y36.17391
X25.57926 Y36.10100
X24.81991 Y35.45264
X24.61721 Y35.24993
X23.96885 Y34.49058
X23.89594 Y34.39887
X23.35484 Y33.54781
X23.11779 Y33.06758
X22.96124 Y32.69674
X22.65234 Y31.84568
X21.18293 Y32.15258
X19.71353 Y32.45948
X19.57703 Y31.84568
X19.44609 Y30.99461
X19.37626 Y30.14355
Y29.29249
X19.44609 Y28.44142
X19.57703 Y27.59036
X19.71353 Y26.97655
X19.77269 Y26.73929
X20.06416 Y25.88823
X20.42342 Y25.03717
X20.56460 Y24.73623
X20.86721 Y24.18610
X21.41661 Y23.33504
X22.09319 Y22.48397
X22.26672 Y22.29394
X22.92776 Y21.63291
X23.11779 Y21.45938
X23.96885 Y20.78280
X24.81991 Y20.23340
X25.37004 Y19.93078
X25.67098 Y19.78961
X26.52204 Y19.43034
X27.37311 Y19.13888
X27.61036 Y19.07972
X28.22417 Y18.94322
X29.07523 Y18.81228
X29.92630 Y18.74245
X30.77736
X31.62843 Y18.81228
X32.47949 Y18.94322
X33.09329 Y19.07972
X33.33055 Y19.13888
X34.18162 Y19.43035
X35.03268 Y19.78961
X35.33361 Y19.93078
X35.88374 Y20.23340
X36.73481 Y20.78280
X37.58587 Y21.45938
X37.77590 Y21.63291
X38.43694 Y22.29394
X38.61047 Y22.48397
X39.28800 Y23.33628
X39.83645 Y24.18610
X40.13906 Y24.73623
X40.28024 Y25.03717
X40.63950 Y25.88823
X40.93097 Y26.73929
X40.99013 Y26.97655
X41.12662 Y27.59036
X41.25757 Y28.44142
X41.32740 Y29.29249
Y30.14355
X41.25757 Y30.99461
X41.12663 Y31.84568
X40.99013 Y32.45948
X40.93097 Y32.69674
X40.63950 Y33.54781
X40.28024 Y34.39887
X40.13906 Y34.69979
X39.83644 Y35.24993
X39.28704 Y36.10100
X38.61047 Y36.95206
X38.43694 Y37.14209
X37.77591 Y37.80312
X37.58587 Y37.97666
X36.73357 Y38.65419
X35.88374 Y39.20263
X35.33361 Y39.50525
X35.03268 Y39.64642
X34.18162 Y40.00569
X33.33055 Y40.29716
X33.09329 Y40.35632
X32.47949 Y40.49281
X31.62843 Y40.62376
X30.77736 Y40.69358
X29.92630
X29.07523 Y40.62376
X28.22417 Y40.49281
X27.61036 Y40.35632
X27.37311 Y40.29716
X26.52204 Y40.00569
X25.67098 Y39.64643
X25.37005 Y39.50525
X24.81991 Y39.20264
X23.96885 Y38.65324
X23.11779 Y37.97666
X22.92776 Y37.80312
X22.26672 Y37.14209
X22.09319 Y36.95206
X21.41566 Y36.09975
X20.86721 Y35.24993
X20.56460 Y34.69980
X20.42342 Y34.39887
X20.06416 Y33.54781
X19.77269 Y32.69674
X19.71353 Y32.45948
X18.30329 Y33.00364
X16.89304 Y33.54781
X16.68084 Y32.69674
X16.53072 Y31.84568
X16.42148 Y30.99461
X16.37099 Y30.14355
Y29.29249
X16.42148 Y28.44142
X16.53071 Y27.59036
X16.68084 Y26.73929
X16.89304 Y25.88823
X17.17558 Y25.03717
X17.50897 Y24.18610
X17.90822 Y23.33504
X18.01140 Y23.13315
X18.38566 Y22.48397
X18.86247 Y21.73985
X19.59329 Y20.78185
X19.71353 Y20.64098
X20.36207 Y19.93078
X20.56460 Y19.72826
X21.27479 Y19.07972
X21.41566 Y18.95948
X22.37366 Y18.22866
X23.11779 Y17.75185
X23.76696 Y17.37759
X23.96885 Y17.27440
X24.81991 Y16.87515
X25.71162 Y16.52653
X26.52204 Y16.25923
X27.37311 Y16.04703
X28.22417 Y15.89690
X29.07523 Y15.78767
X29.92630 Y15.73717
X30.77736
X31.62843 Y15.78767
X32.47949 Y15.89690
X33.33055 Y16.04703
X34.18162 Y16.25923
X35.03268 Y16.54176
X35.88374 Y16.87515
X36.73481 Y17.27440
X36.93670 Y17.37759
X37.58587 Y17.75185
X38.33000 Y18.22866
X39.28800 Y18.95947
X39.42887 Y19.07972
X40.13906 Y19.72826
X40.34159 Y19.93078
X40.99013 Y20.64098
X41.11037 Y20.78185
X41.84119 Y21.73985
X42.31800 Y22.48397
X42.69226 Y23.13316
X42.79544 Y23.33504
X43.19469 Y24.18610
X43.54332 Y25.07780
X43.81062 Y25.88823
X44.02281 Y26.73929
X44.17294 Y27.59036
X44.28218 Y28.44142
X44.33267 Y29.29249
Y30.14355
X44.28218 Y30.99461
X44.17294 Y31.84568
X44.02282 Y32.69674
X43.81062 Y33.54781
X43.52808 Y34.39887
X43.19469 Y35.24993
X42.79544 Y36.10100
X42.69226 Y36.30287
X42.31799 Y36.95206
X41.84119 Y37.69619
X41.11037 Y38.65419
X40.99013 Y38.79506
X40.34159 Y39.50525
X40.13906 Y39.70778
X39.42887 Y40.35632
X39.28800 Y40.47656
X38.33000 Y41.20738
X37.58587 Y41.68418
X36.93668 Y42.05844
X36.73481 Y42.16163
X35.88374 Y42.56088
X34.99204 Y42.90951
X34.18162 Y43.17680
X33.33055 Y43.38900
X32.47949 Y43.53913
X31.62843 Y43.64837
X30.77736 Y43.69886
X29.92630
X29.07523 Y43.64837
X28.22417 Y43.53913
X27.37311 Y43.38900
X26.52204 Y43.17681
X25.67098 Y42.89427
X24.81991 Y42.56088
X23.96885 Y42.16163
X23.76697 Y42.05844
X23.11779 Y41.68419
X22.37366 Y41.20738
X21.41566 Y40.47656
X21.27479 Y40.35632
X20.56460 Y39.70778
X20.36207 Y39.50525
X19.71353 Y38.79506
X19.59329 Y38.65419
X18.86247 Y37.69619
X18.38566 Y36.95206
X18.01140 Y36.30288
X17.90822 Y36.10100
X17.50897 Y35.24993
X17.16034 Y34.35823
X16.89304 Y33.54781
X15.46228 Y34.00869
X14.03151 Y34.46957
X13.72725 Y33.26149
X13.51590 Y32.06058
X13.39312 Y30.87617
X13.35358 Y29.71796
X13.39134 Y28.55968
X13.51405 Y27.37514
X13.72533 Y26.17406
X14.02956 Y24.96581
X14.42981 Y23.76073
X14.92769 Y22.56988
X15.52310 Y21.40485
X16.21415 Y20.27736
X16.99707 Y19.19897
X17.86628 Y18.18064
X18.81446 Y17.23247
X19.83278 Y16.36326
X20.91117 Y15.58034
X22.03866 Y14.88929
X23.20369 Y14.29388
X24.39454 Y13.79600
X25.59963 Y13.39575
X26.80787 Y13.09152
X28.00895 Y12.88024
X29.19349 Y12.75753
X30.35183 Y12.71802
X31.51017 Y12.75753
X32.69471 Y12.88024
X33.89579 Y13.09152
X35.10403 Y13.39575
X36.30913 Y13.79600
X37.49996 Y14.29387
X38.66499 Y14.88929
X39.79248 Y15.58034
X40.87089 Y16.36326
X41.88920 Y17.23247
X42.83739 Y18.18064
X43.70482 Y19.20047
X44.48766 Y20.27871
X45.17864 Y21.40602
X45.77402 Y22.57088
X46.27189 Y23.76155
X46.67215 Y24.96646
X46.97641 Y26.17454
X47.18776 Y27.37547
X47.31054 Y28.55986
X47.35008 Y29.71807
X47.31052 Y30.87630
X47.18774 Y32.06070
X46.97638 Y33.26163
X46.67211 Y34.46973
X46.27183 Y35.67464
X45.77395 Y36.86531
X45.17856 Y38.03016
X44.48756 Y39.15748
X43.70471 Y40.23571
X42.83561 Y41.25389
X41.88756 Y42.20193
X40.86938 Y43.07101
X39.79115 Y43.85384
X38.66382 Y44.54483
X37.49896 Y45.14021
X36.30830 Y45.63808
X35.10339 Y46.03834
X33.89530 Y46.34260
X32.69439 Y46.55395
X31.50999 Y46.67672
X30.35177 Y46.71627
X29.19356 Y46.67671
X28.00914 Y46.55392
X26.80821 Y46.34257
X25.60013 Y46.03830
X24.39521 Y45.63802
X23.20454 Y45.14014
X22.03968 Y44.54475
X20.91237 Y43.85375
X19.83414 Y43.07090
X18.81597 Y42.20180
X17.86793 Y41.25375
X16.99883 Y40.23557
X16.21600 Y39.15733
X15.52501 Y38.03001
X14.92964 Y36.86515
X14.43178 Y35.67449
X14.03151 Y34.46957
G00 Z13.00000
Z9.67933
G01 Z6.67933 F350
X31.80514 Y30.99461 Z6.58210 F350
X31.62843 Y31.17133 Z6.53803
X30.77736 Y31.62661 Z6.36784
X29.92630 Z6.21778
X29.07523 Y31.17132 Z6.04759
X28.89853 Y30.99461 Z6.00352
X28.44323 Y30.14355 Z5.83333
Y29.29249
X28.89853 Y28.44142
X29.07523 Y28.26471
X29.92630 Y27.80942
X30.77736
X31.62843 Y28.26471
X31.80514 Y28.44142
X32.26043 Y29.29249
Y30.14355
X31.80514 Y30.99461
X31.62843 Y31.17133
X30.77736 Y31.62661
X29.92630
X29.07523 Y31.17132
X28.89853 Y30.99461
X28.44323 Y30.14355
X26.99227 Y30.56908
X25.54131 Y30.99461
X25.40499 Y30.14355
Y29.29249
X25.54131 Y28.44142
X25.67098 Y28.06660
X25.86021 Y27.59036
X26.38199 Y26.73929
X26.52204 Y26.57526
X27.20907 Y25.88823
X27.37311 Y25.74817
X28.22417 Y25.22640
X28.70041 Y25.03717
X29.07523 Y24.90750
X29.92630 Y24.77118
X30.77736
X31.62843 Y24.90750
X32.00325 Y25.03717
X32.47949 Y25.22640
X33.33055 Y25.74817
X33.49459 Y25.88823
X34.18162 Y26.57526
X34.32167 Y26.73929
X34.84344 Y27.59036
X35.03268 Y28.06660
X35.16235 Y28.44142
X35.29866 Y29.29249
Y30.14355
X35.16235 Y30.99461
X35.03268 Y31.36944
X34.84344 Y31.84568
X34.32167 Y32.69674
X34.18162 Y32.86077
X33.49459 Y33.54781
X33.33055 Y33.68786
X32.47949 Y34.20963
X32.00325 Y34.39887
X31.62843 Y34.52854
X30.77736 Y34.66485
X29.92630
X29.07523 Y34.52854
X28.70041 Y34.39887
X28.22417 Y34.20964
X27.37311 Y33.68786
X27.20907 Y33.54781
X26.52204 Y32.86077
X26.38199 Y32.69674
X25.86021 Y31.84568
X25.67098 Y31.36944
X25.54131 Y30.99461
X24.09682 Y31.42015
X22.65234 Y31.84568
X22.48139 Y30.99461
X22.38634 Y30.14355
Y29.29249
X22.48139 Y28.44142
X22.65233 Y27.59036
X22.96124 Y26.73929
X23.11779 Y26.36845
X23.35484 Y25.88823
X23.89594 Y25.03717
X23.96885 Y24.94545
X24.61721 Y24.18610
X24.81991 Y23.98339
X25.57926 Y23.33504
X25.67098 Y23.26213
X26.52204 Y22.72102
X27.00226 Y22.48397
X27.37311 Y22.32743
X28.22417 Y22.01852
X29.07523 Y21.84758
X29.92630 Y21.75253
X30.77736
X31.62843 Y21.84758
X32.47949 Y22.01852
X33.33055 Y22.32743
X33.70140 Y22.48397
X34.18162 Y22.72102
X35.03268 Y23.26213
X35.12440 Y23.33504
X35.88374 Y23.98339
X36.08645 Y24.18610
X36.73481 Y24.94545
X36.80772 Y25.03717
X37.34883 Y25.88823
X37.58587 Y26.36845
X37.74242 Y26.73929
X38.05133 Y27.59036
X38.22227 Y28.44142
X38.31731 Y29.29249
Y30.14355
X38.22227 Y30.99461
X38.05132 Y31.84568
X37.74242 Y32.69674
X37.58587 Y33.06758
X37.34882 Y33.54781
X36.80772 Y34.39887
X36.73481 Y34.49058
X36.08646 Y35.24993
X35.88374 Y35.45265
X35.12439 Y36.10100
X35.03268 Y36.17391
X34.18162 Y36.71501
X33.70140 Y36.95206
X33.33055 Y37.10861
X32.47949 Y37.41751
X31.62843 Y37.58846
X30.77736 Y37.68350
X29.92630
X29.07523 Y37.58846
X28.22417 Y37.41751
X27.37311 Y37.10861
X27.00225 Y36.95206
X26.52204 Y36.71502
X25.67098 Y36.17391
X25.57926 Y36.10100
X24.81991 Y35.45264
X24.61721 Y35.24993
X23.96885 Y34.49058
X23.89594 Y34.39887
X23.35484 Y33.54781
X23.11779 Y33.06758
X22.96124 Y32.69674
X22.65234 Y31.84568
X21.18293 Y32.15258
X19.71353 Y32.45948
X19.57703 Y31.84568
X19.44609 Y30.99461
X19.37626 Y30.14355
Y29.29249
X19.44609 Y28.44142
X19.57703 Y27.59036
X19.71353 Y26.97655
X19.77269 Y26.73929
X20.06416 Y25.88823
X20.42342 Y25.03717
X20.56460 Y24.73623
X20.86721 Y24.18610
X21.41661 Y23.33504
X22.09319 Y22.48397
X22.26672 Y22.29394
X22.92776 Y21.63291
X23.11779 Y21.45938
X23.96885 Y20.78280
X24.81991 Y20.23340
X25.37004 Y19.93078
X25.67098 Y19.78961
X26.52204 Y19.43034
X27.37311 Y19.13888
X27.61036 Y19.07972
X28.22417 Y18.94322
X29.07523 Y18.81228
X29.92630 Y18.74245
X30.77736
X31.62843 Y18.81228
X32.47949 Y18.94322
X33.09329 Y19.07972
X33.33055 Y19.13888
X34.18162 Y19.43035
X35.03268 Y19.78961
X35.33361 Y19.93078
X35.88374 Y20.23340
X36.73481 Y20.78280
X37.58587 Y21.45938
X37.77590 Y21.63291
X38.43694 Y22.29394
X38.61047 Y22.48397
X39.28800 Y23.33628
X39.83645 Y24.18610
X40.13906 Y24.73623
X40.28024 Y25.03717
X40.63950 Y25.88823
X40.93097 Y26.73929
X40.99013 Y26.97655
X41.12662 Y27.59036
X41.25757 Y28.44142
X41.32740 Y29.29249
Y30.14355
X41.25757 Y30.99461
X41.12663 Y31.84568
X40.99013 Y32.45948
X40.93097 Y32.69674
X40.63950 Y33.54781
X40.28024 Y34.39887
X40.13906 Y34.69979
X39.83644 Y35.24993
X39.28704 Y36.10100
X38.61047 Y36.95206
X38.43694 Y37.14209
X37.77591 Y37.80312
X37.58587 Y37.97666
X36.73357 Y38.65419
X35.88374 Y39.20263
X35.33361 Y39.50525
X35.03268 Y39.64642
X34.18162 Y40.00569
X33.33055 Y40.29716
X33.09329 Y40.35632
X32.47949 Y40.49281
X31.62843 Y40.62376
X30.77736 Y40.69358
X29.92630
X29.07523 Y40.62376
X28.22417 Y40.49281
X27.61036 Y40.35632
X27.37311 Y40.29716
X26.52204 Y40.00569
X25.67098 Y39.64643
X25.37005 Y39.50525
X24.81991 Y39.20264
X23.96885 Y38.65324
X23.11779 Y37.97666
X22.92776 Y37.80312
X22.26672 Y37.14209
X22.09319 Y36.95206
X21.41566 Y36.09975
X20.86721 Y35.24993
X20.56460 Y34.69980
X20.42342 Y34.39887
X20.06416 Y33.54781
X19.77269 Y32.69674
X19.71353 Y32.45948
X18.30329 Y33.00364
X16.89304 Y33.54781
X16.68084 Y32.69674
X16.53072 Y31.84568
X16.42148 Y30.99461
X16.37099 Y30.14355
Y29.29249
X16.42148 Y28.44142
X16.53071 Y27.59036
X16.68084 Y26.73929
X16.89304 Y25.88823
X17.17558 Y25.03717
X17.50897 Y24.18610
X17.90822 Y23.33504
X18.01140 Y23.13315
X18.38566 Y22.48397
X18.86247 Y21.73985
X19.59329 Y20.78185
X19.71353 Y20.64098
X20.36207 Y19.93078
X20.56460 Y19.72826
X21.27479 Y19.07972
X21.41566 Y18.95948
X22.37366 Y18.22866
X23.11779 Y17.75185
X23.76696 Y17.37759
X23.96885 Y17.27440
X24.81991 Y16.87515
X25.71162 Y16.52653
X26.52204 Y16.25923
X27.37311 Y16.04703
X28.22417 Y15.89690
X29.07523 Y15.78767
X29.92630 Y15.73717
X30.77736
X31.62843 Y15.78767
X32.47949 Y15.89690
X33.33055 Y16.04703
X34.18162 Y16.25923
X35.03268 Y16.54176
X35.88374 Y16.87515
X36.73481 Y17.27440
X36.93670 Y17.37759
X37.58587 Y17.75185
X38.33000 Y18.22866
X39.28800 Y18.95947
X39.42887 Y19.07972
X40.13906 Y19.72826
X40.34159 Y19.93078
X40.99013 Y20.64098
X41.11037 Y20.78185
X41.84119 Y21.73985
X42.31800 Y22.48397
X42.69226 Y23.13316
X42.79544 Y23.33504
X43.19469 Y24.18610
X43.54332 Y25.07780
X43.81062 Y25.88823
X44.02281 Y26.73929
X44.17294 Y27.59036
X44.28218 Y28.44142
X44.33267 Y29.29249
Y30.14355
X44.28218 Y30.99461
X44.17294 Y31.84568
X44.02282 Y32.69674
X43.81062 Y33.54781
X43.52808 Y34.39887
X43.19469 Y35.24993
X42.79544 Y36.10100
X42.69226 Y36.30287
X42.31799 Y36.95206
X41.84119 Y37.69619
X41.11037 Y38.65419
X40.99013 Y38.79506
X40.34159 Y39.50525
X40.13906 Y39.70778
X39.42887 Y40.35632
X39.28800 Y40.47656
X38.33000 Y41.20738
X37.58587 Y41.68418
X36.93668 Y42.05844
X36.73481 Y42.16163
X35.88374 Y42.56088
X34.99204 Y42.90951
X34.18162 Y43.17680
X33.33055 Y43.38900
X32.47949 Y43.53913
X31.62843 Y43.64837
X30.77736 Y43.69886
X29.92630
X29.07523 Y43.64837
X28.22417 Y43.53913
X27.37311 Y43.38900
X26.52204 Y43.17681
X25.67098 Y42.89427
X24.81991 Y42.56088
X23.96885 Y42.16163
X23.76697 Y42.05844
X23.11779 Y41.68419
X22.37366 Y41.20738
X21.41566 Y40.47656
X21.27479 Y40.35632
X20.56460 Y39.70778
X20.36207 Y39.50525
X19.71353 Y38.79506
X19.59329 Y38.65419
X18.86247 Y37.69619
X18.38566 Y36.95206
X18.01140 Y36.30288
X17.90822 Y36.10100
X17.50897 Y35.24993
X17.16034 Y34.35823
X16.89304 Y33.54781
X15.46228 Y34.00869
X14.03151 Y34.46957
X13.72725 Y33.26149
X13.51590 Y32.06058
X13.39312 Y30.87617
X13.35358 Y29.71796
X13.39134 Y28.55968
X13.51405 Y27.37514
X13.72533 Y26.17406
X14.02956 Y24.96581
X14.42981 Y23.76073
X14.92769 Y22.56988
X15.52310 Y21.40485
X16.21415 Y20.27736
X16.99707 Y19.19897
X17.86628 Y18.18064
X18.81446 Y17.23247
X19.83278 Y16.36326
X20.91117 Y15.58034
X22.03866 Y14.88929
X23.20369 Y14.29388
X24.39454 Y13.79600
X25.59963 Y13.39575
X26.80787 Y13.09152
X28.00895 Y12.88024
X29.19349 Y12.75753
X30.35183 Y12.71802
X31.51017 Y12.75753
X32.69471 Y12.88024
X33.89579 Y13.09152
X35.10403 Y13.39575
X36.30913 Y13.79600
X37.49996 Y14.29387
X38.66499 Y14.88929
X39.79248 Y15.58034
X40.87089 Y16.36326
X41.88920 Y17.23247
X42.83739 Y18.18064
X43.70482 Y19.20047
X44.48766 Y20.27871
X45.17864 Y21.40602
X45.77402 Y22.57088
X46.27189 Y23.76155
X46.67215 Y24.96646
X46.97641 Y26.17454
X47.18776 Y27.37547
X47.31054 Y28.55986
X47.35008 Y29.71807
X47.31052 Y30.87630
X47.18774 Y32.06070
X46.97638 Y33.26163
X46.67211 Y34.46973
X46.27183 Y35.67464
X45.77395 Y36.86531
X45.17856 Y38.03016
X44.48756 Y39.15748
X43.70471 Y40.23571
X42.83561 Y41.25389
X41.88756 Y42.20193
X40.86938 Y43.07101
X39.79115 Y43.85384
X38.66382 Y44.54483
X37.49896 Y45.14021
X36.30830 Y45.63808
X35.10339 Y46.03834
X33.89530 Y46.34260
X32.69439 Y46.55395
X31.50999 Y46.67672
X30.35177 Y46.71627
X29.19356 Y46.67671
X28.00914 Y46.55392
X26.80821 Y46.34257
X25.60013 Y46.03830
X24.39521 Y45.63802
X23.20454 Y45.14014
X22.03968 Y44.54475
X20.91237 Y43.85375
X19.83414 Y43.07090
X18.81597 Y42.20180
X17.86793 Y41.25375
X16.99883 Y40.23557
X16.21600 Y39.15733
X15.52501 Y38.03001
X14.92964 Y36.86515
X14.43178 Y35.67449
X14.03151 Y34.46957
G00 Z13.00000
Z8.84600
G01 Z5.84600 F350
X31.80514 Y30.99461 Z5.74877 F350
X31.62843 Y31.17133 Z5.70470
X30.77736 Y31.62661 Z5.53451
X29.92630 Z5.38445
X29.07523 Y31.17132 Z5.21426
X28.89853 Y30.99461 Z5.17019
X28.44323 Y30.14355 Z5.00000
Y29.29249
X28.89853 Y28.44142
X29.07523 Y28.26471
X29.92630 Y27.80942
X30.77736
X31.62843 Y28.26471
X31.80514 Y28.44142
X32.26043 Y29.29249
Y30.14355
X31.80514 Y30.99461
X31.62843 Y31.17133
X30.77736 Y31.62661
X29.92630
X29.07523 Y31.17132
X28.89853 Y30.99461
X28.44323 Y30.14355
X26.99227 Y30.56908
X25.54131 Y30.99461
X25.40499 Y30.14355
Y29.29249
X25.54131 Y28.44142
X25.67098 Y28.06660
X25.86021 Y27.59036
X26.38199 Y26.73929
X26.52204 Y26.57526
X27.20907 Y25.88823
X27.37311 Y25.74817
X28.22417 Y25.22640
X28.70041 Y25.03717
X29.07523 Y24.90750
X29.92630 Y24.77118
X30.77736
X31.62843 Y24.90750
X32.00325 Y25.03717
X32.47949 Y25.22640
X33.33055 Y25.74817
X33.49459 Y25.88823
X34.18162 Y26.57526
X34.32167 Y26.73929
X34.84344 Y27.59036
X35.03268 Y28.06660
X35.16235 Y28.44142
X35.29866 Y29.29249
Y30.14355
X35.16235 Y30.99461
X35.03268 Y31.36944
X34.84344 Y31.84568
X34.32167 Y32.69674
X34.18162 Y32.86077
X33.49459 Y33.54781
X33.33055 Y33.68786
X32.47949 Y34.20963
X32.00325 Y34.39887
X31.62843 Y34.52854
X30.77736 Y34.66485
X29.92630
X29.07523 Y34.52854
X28.70041 Y34.39887
X28.22417 Y34.20964
X27.37311 Y33.68786
X27.20907 Y33.54781
X26.52204 Y32.86077
X26.38199 Y32.69674
X25.86021 Y31.84568
X25.67098 Y31.36944
X25.54131 Y30.99461
X24.09682 Y31.42015
X22.65234 Y31.84568
X22.48139 Y30.99461
X22.38634 Y30.14355
Y29.29249
X22.48139 Y28.44142
X22.65233 Y27.59036
X22.96124 Y26.73929
X23.11779 Y26.36845
X23.35484 Y25.88823
X23.89594 Y25.03717
X23.96885 Y24.94545
X24.61721 Y24.18610
X24.81991 Y23.98339
X25.57926 Y23.33504
X25.67098 Y23.26213
X26.52204 Y22.72102
X27.00226 Y22.48397
X27.37311 Y22.32743
X28.22417 Y22.01852
X29.07523 Y21.84758
X29.92630 Y21.75253
X30.77736
X31.62843 Y21.84758
X32.47949 Y22.01852
X33.33055 Y22.32743
X33.70140 Y22.48397
X34.18162 Y22.72102
X35.03268 Y23.26213
X35.12440 Y23.33504
X35.88374 Y23.98339
X36.08645 Y24.18610
X36.73481 Y24.94545
X36.80772 Y25.03717
X37.34883 Y25.88823
X37.58587 Y26.36845
X37.74242 Y26.73929
X38.05133 Y27.59036
X38.22227 Y28.44142
X38.31731 Y29.29249
Y30.14355
X38.22227 Y30.99461
X38.05132 Y31.84568
X37.74242 Y32.69674
X37.58587 Y33.06758
X37.34882 Y33.54781
X36.80772 Y34.39887
X36.73481 Y34.49058
X36.08646 Y35.24993
X35.88374 Y35.45265
X35.12439 Y36.10100
X35.03268 Y36.17391
X34.18162 Y36.71501
X33.70140 Y36.95206
X33.33055 Y37.10861
X32.47949 Y37.41751
X31.62843 Y37.58846
X30.77736 Y37.68350
X29.92630
X29.07523 Y37.58846
X28.22417 Y37.41751
X27.37311 Y37.10861
X27.00225 Y36.95206
X26.52204 Y36.71502
X25.67098 Y36.17391
X25.57926 Y36.10100
X24.81991 Y35.45264
X24.61721 Y35.24993
X23.96885 Y34.49058
X23.89594 Y34.39887
X23.35484 Y33.54781
X23.11779 Y33.06758
X22.96124 Y32.69674
X22.65234 Y31.84568
X21.18293 Y32.15258
X19.71353 Y32.45948
X19.57703 Y31.84568
X19.44609 Y30.99461
X19.37626 Y30.14355
Y29.29249
X19.44609 Y28.44142
X19.57703 Y27.59036
X19.71353 Y26.97655
X19.77269 Y26.73929
X20.06416 Y25.88823
X20.42342 Y25.03717
X20.56460 Y24.73623
X20.86721 Y24.18610
X21.41661 Y23.33504
X22.09319 Y22.48397
X22.26672 Y22.29394
X22.92776 Y21.63291
X23.11779 Y21.45938
X23.96885 Y20.78280
X24.81991 Y20.23340
X25.37004 Y19.93078
X25.67098 Y19.78961
X26.52204 Y19.43034
X27.37311 Y19.13888
X27.61036 Y19.07972
X28.22417 Y18.94322
X29.07523 Y18.81228
X29.92630 Y18.74245
X30.77736
X31.62843 Y18.81228
X32.47949 Y18.94322
X33.09329 Y19.07972
X33.33055 Y19.13888
X34.18162 Y19.43035
X35.03268 Y19.78961
X35.33361 Y19.93078
X35.88374 Y20.23340
X36.73481 Y20.78280
X37.58587 Y21.45938
X37.77590 Y21.63291
X38.43694 Y22.29394
X38.61047 Y22.48397
X39.28800 Y23.33628
X39.83645 Y24.18610
X40.13906 Y24.73623
X40.28024 Y25.03717
X40.63950 Y25.88823
X40.93097 Y26.73929
X40.99013 Y26.97655
X41.12662 Y27.59036
X41.25757 Y28.44142
X41.32740 Y29.29249
Y30.14355
X41.25757 Y30.99461
X41.12663 Y31.84568
X40.99013 Y32.45948
X40.93097 Y32.69674
X40.63950 Y33.54781
X40.28024 Y34.39887
X40.13906 Y34.69979
X39.83644 Y35.24993
X39.28704 Y36.10100
X38.61047 Y36.95206
X38.43694 Y37.14209
X37.77591 Y37.80312
X37.58587 Y37.97666
X36.73357 Y38.65419
X35.88374 Y39.20263
X35.33361 Y39.50525
X35.03268 Y39.64642
X34.18162 Y40.00569
X33.33055 Y40.29716
X33.09329 Y40.35632
X32.47949 Y40.49281
X31.62843 Y40.62376
X30.77736 Y40.69358
X29.92630
X29.07523 Y40.62376
X28.22417 Y40.49281
X27.61036 Y40.35632
X27.37311 Y40.29716
X26.52204 Y40.00569
X25.67098 Y39.64643
X25.37005 Y39.50525
X24.81991 Y39.20264
X23.96885 Y38.65324
X23.11779 Y37.97666
X22.92776 Y37.80312
X22.26672 Y37.14209
X22.09319 Y36.95206
X21.41566 Y36.09975
X20.86721 Y35.24993
X20.56460 Y34.69980
X20.42342 Y34.39887
X20.06416 Y33.54781
X19.77269 Y32.69674
X19.71353 Y32.45948
X18.30329 Y33.00364
X16.89304 Y33.54781
X16.68084 Y32.69674
X16.53072 Y31.84568
X16.42148 Y30.99461
X16.37099 Y30.14355
Y29.29249
X16.42148 Y28.44142
X16.53071 Y27.59036
X16.68084 Y26.73929
X16.89304 Y25.88823
X17.17558 Y25.03717
X17.50897 Y24.18610
X17.90822 Y23.33504
X18.01140 Y23.13315
X18.38566 Y22.48397
X18.86247 Y21.73985
X19.59329 Y20.78185
X19.71353 Y20.64098
X20.36207 Y19.93078
X20.56460 Y19.72826
X21.27479 Y19.07972
X21.41566 Y18.95948
X22.37366 Y18.22866
X23.11779 Y17.75185
X23.76696 Y17.37759
X23.96885 Y17.27440
X24.81991 Y16.87515
X25.71162 Y16.52653
X26.52204 Y16.25923
X27.37311 Y16.04703
X28.22417 Y15.89690
X29.07523 Y15.78767
X29.92630 Y15.73717
X30.77736
X31.62843 Y15.78767
X32.47949 Y15.89690
X33.33055 Y16.04703
X34.18162 Y16.25923
X35.03268 Y16.54176
X35.88374 Y16.87515
X36.73481 Y17.27440
X36.93670 Y17.37759
X37.58587 Y17.75185
X38.33000 Y18.22866
X39.28800 Y18.95947
X39.42887 Y19.07972
X40.13906 Y19.72826
X40.34159 Y19.93078
X40.99013 Y20.64098
X41.11037 Y20.78185
X41.84119 Y21.73985
X42.31800 Y22.48397
X42.69226 Y23.13316
X42.79544 Y23.33504
X43.19469 Y24.18610
X43.54332 Y25.07780
X43.81062 Y25.88823
X44.02281 Y26.73929
X44.17294 Y27.59036
X44.28218 Y28.44142
X44.33267 Y29.29249
Y30.14355
X44.28218 Y30.99461
X44.17294 Y31.84568
X44.02282 Y32.69674
X43.81062 Y33.54781
X43.52808 Y34.39887
X43.19469 Y35.24993
X42.79544 Y36.10100
X42.69226 Y36.30287
X42.31799 Y36.95206
X41.84119 Y37.69619
X41.11037 Y38.65419
X40.99013 Y38.79506
X40.34159 Y39.50525
X40.13906 Y39.70778
X39.42887 Y40.35632
X39.28800 Y40.47656
X38.33000 Y41.20738
X37.58587 Y41.68418
X36.93668 Y42.05844
X36.73481 Y42.16163
X35.88374 Y42.56088
X34.99204 Y42.90951
X34.18162 Y43.17680
X33.33055 Y43.38900
X32.47949 Y43.53913
X31.62843 Y43.64837
X30.77736 Y43.69886
X29.92630
X29.07523 Y43.64837
X28.22417 Y43.53913
X27.37311 Y43.38900
X26.52204 Y43.17681
X25.67098 Y42.89427
X24.81991 Y42.56088
X23.96885 Y42.16163
X23.76697 Y42.05844
X23.11779 Y41.68419
X22.37366 Y41.20738
X21.41566 Y40.47656
X21.27479 Y40.35632
X20.56460 Y39.70778
X20.36207 Y39.50525
X19.71353 Y38.79506
X19.59329 Y38.65419
X18.86247 Y37.69619
X18.38566 Y36.95206
X18.01140 Y36.30288
X17.90822 Y36.10100
X17.50897 Y35.24993
X17.16034 Y34.35823
X16.89304 Y33.54781
X15.46228 Y34.00869
X14.03151 Y34.46957
X13.72725 Y33.26149
X13.51590 Y32.06058
X13.39312 Y30.87617
X13.35358 Y29.71796
X13.39134 Y28.55968
X13.51405 Y27.37514
X13.72533 Y26.17406
X14.02956 Y24.96581
X14.42981 Y23.76073
X14.92769 Y22.56988
X15.52310 Y21.40485
X16.21415 Y20.27736
X16.99707 Y19.19897
X17.86628 Y18.18064
X18.81446 Y17.23247
X19.83278 Y16.36326
X20.91117 Y15.58034
X22.03866 Y14.88929
X23.20369 Y14.29388
X24.39454 Y13.79600
X25.59963 Y13.39575
X26.80787 Y13.09152
X28.00895 Y12.88024
X29.19349 Y12.75753
X30.35183 Y12.71802
X31.51017 Y12.75753
X32.69471 Y12.88024
X33.89579 Y13.09152
X35.10403 Y13.39575
X36.30913 Y13.79600
X37.49996 Y14.29387
X38.66499 Y14.88929
X39.79248 Y15.58034
X40.87089 Y16.36326
X41.88920 Y17.23247
X42.83739 Y18.18064
X43.70482 Y19.20047
X44.48766 Y20.27871
X45.17864 Y21.40602
X45.77402 Y22.57088
X46.27189 Y23.76155
X46.67215 Y24.96646
X46.97641 Y26.17454
X47.18776 Y27.37547
X47.31054 Y28.55986
X47.35008 Y29.71807
X47.31052 Y30.87630
X47.18774 Y32.06070
X46.97638 Y33.26163
X46.67211 Y34.46973
X46.27183 Y35.67464
X45.77395 Y36.86531
X45.17856 Y38.03016
X44.48756 Y39.15748
X43.70471 Y40.23571
X42.83561 Y41.25389
X41.88756 Y42.20193
X40.86938 Y43.07101
X39.79115 Y43.85384
X38.66382 Y44.54483
X37.49896 Y45.14021
X36.30830 Y45.63808
X35.10339 Y46.03834
X33.89530 Y46.34260
X32.69439 Y46.55395
X31.50999 Y46.67672
X30.35177 Y46.71627
X29.19356 Y46.67671
X28.00914 Y46.55392
X26.80821 Y46.34257
X25.60013 Y46.03830
X24.39521 Y45.63802
X23.20454 Y45.14014
X22.03968 Y44.54475
X20.91237 Y43.85375
X19.83414 Y43.07090
X18.81597 Y42.20180
X17.86793 Y41.25375
X16.99883 Y40.23557
X16.21600 Y39.15733
X15.52501 Y38.03001
X14.92964 Y36.86515
X14.43178 Y35.67449
X14.03151 Y34.46957
G00 Z9.00000
G00 Z13.00000
M09
M30
