586,391 active members*
3,155 visitors online*
Page 12 of 12 2101112
Results 221 to 233 of 233
  1. #221
    WoodNDust Guest
    Re: Joes CNC Model 2006 R-1
    First off, I would like to thank Joe publicly for providing his 2006 R2 plans. I have been studying various videos and websites to either find an existing design for my first CNC build. This appears to be a good starting point. I plan to try to build this machine with a 4x4 cutting area.
    I like the torsion box design but have been wondering the reason for the routed holes in the torsion framework. Why not just route the slots and keep the boards otherwise solid?
    Also wondering, from DIYer's who have built the machine, how well does the black pipe work for the linear rails? I have seen at least one build use turned, hardened and ground rail stock in place of the pipe.
    Thanks.
  2. #222
    Feb 2006
    210
    The holes are prob for lightening. Also, the kits are/were cut on a CNC so they were easy. If you are cutting by hand just omit them but make sure they are not a pass thru for a lead screw etc.
    Dave
    In the words of the Toolman--If you didn't make it yourself, it's not really yours!
    Remember- done beats perfect every time!!
  3. #223
    Aug 2003
    329
    If you plan to build a 4x4 you should gret the plans for Joes 4x4 hybrid instead. MDF will sag if much longer than 3'. To build a 4x4 takes about 6'x6' of area. In my opinion building the Hybrid is the better course if you want a larger machine.
    If you told me you planned to build a machine exactly as the plans show, then II would say the 2006 is a great choice. Once you start extending the table you are better off with a Hybrid.
    Bill
    Joescnc 4x4 R&P Router, Minimill, Minilathe, CNC Foamcutter, laser cutter, Vectric Aspire. http://makermasters.com, http://themakersguide.com
  4. #224
    WoodNDust Guest
    That makes sense about the holes. I was also thinking they might be for evening out temperature/moisture to keep the table more stable, but this is just speculation on my part.
    Quote Originally Posted by beone View Post
    Dave
  5. #225
    WoodNDust Guest
    Thanks Bill. I would like to avoid using aluminum extrusions because of their high cost. I do have access to a CNC plasma cutter, so I am planning to utilize 1/8" steel sheet to cut some of the plates in wood and steel and then laminate for strength. Really, I'm just looking things over and working with elements of this design, as well as other designs to come up with a hybrid of my own that avoids aluminum extrusions.
    Quote Originally Posted by bgriggs View Post
    Bill
  6. #226
    Jul 2017
    4
    Joe could I Please get a copy of the DWGS thanks [email protected]
  7. #227
    Apr 2017
    4
    Quote Originally Posted by Koday94 View Post
    What format would you like them in? I looked around for awhile and found them in SketchUp, STL, SolidWorks, Pro-E, AutoCAD. I have the zip files I can send to you.
  8. #228
    May 2014
    Hi Joe, could I also ask for a copy of the plans please? Sketch-up or Autocad (2006) would be great. Many thanks.
  9. #229
    Apr 2018
    can i get a copy dwg
  10. #230
    Apr 2018
    me to please
    Quote Originally Posted by davdue View Post
  11. #231
    Apr 2018
    Hi can you send me the zip (AutoCAD) and thank you
  12. #232
    Apr 2017
    4
    Quote Originally Posted by gsxdax View Post
    I'm not sure this is the latest. It has an older date from the R2 ones that I have in other formats.
  13. #233
    Oct 2018
    Thank you for this.
  1. Joes CNC Model 2006 in Vancouver, Wa
    By flyon in forum Joes CNC Model 2006
    Last Post: 10-14-2015, 01:17 AM
  2. Joes CNC Model 2006 R-2 plans and edrawing dimensioning
    By javarik in forum Joes CNC Model 2006
    Last Post: 09-26-2010, 02:11 AM
  3. Selling a Joes CNC Model 2006 R1
    By finless139 in forum Joes CNC Model 2006
    Last Post: 04-30-2010, 03:26 AM
  4. Joes CNC Model 2006 in metric
    By pklecz in forum Joes CNC Model 2006
    Last Post: 12-10-2009, 01:23 PM
  5. JOES cnc MODEL 2006 R-1 or R-2???
    By Khalid in forum Joes CNC Model 2006
    Last Post: 11-11-2007, 06:58 PM
