Originally Posted by
Zetopan
What all of this means is that as the rotary table winds up from 0.0 degrees to
90,000 degrees each step that it can precisely take becomes larger and larger.
If you ever command the table to rotate by a large sequence of incremental
steps and any of those steps is not an exact integer multiple of the available
resolution at that degree setting, the actual movement would get rounded
to the nearest numeric value that the floating point can represent. Hence,
each movement is ever so slightly inaccurate and accumulating enough of
these can cause problems.
