so ive got me a new raptor thats almost assembled (blue one, pics have been posted). im working on adjustemnts and mods to make it a bit more "turnkey friendly"
had been trying to figure out what servo power and ball screws would yield a good result. im used to steppers, which provide tend to provide alot of torque at 0, and little to none at speed.
yaskawa has some new servos, called the junma series. they are 100-750w, take step and direction, and autotune themselves within a reasonable inertia ratio. they have an app that will tell you what motor is needed based on the machine spec and performance desired. these motors and drives are specifically made to be replacements for steppers, so they are simple to set up, if slightly more limited in function than a full featured industrial kit.
it was really quite surprising seeing the results and recomendations.
a 24x48 raptor (18"x40" safe travel) with a 1hp er20 spindle is the basic example. the performance requirements were set very high, and included cutting feed forces agressive enough to stall the spindle. weight was exaggerated slightly to account for variables and acessories.
25mm x 20 pitch ball screw on the x, 15mm x 20mm pitch on the y and z.
all axes have a 2:1 belt drive and as such, a 1181 ipm rapid speed with a 3000rpm motor. acelleration was set to 0.5G.
this is fully 3x faster acceleration and top speed than a typical raptor with chinese steppers and gecko drives.
for the X axis, the recomended motor is 400w.
for the y and z axis, the recomended motor is 200w.
if you reduce the top speed to 590ipm by using a 10 pitch screw, and use a 20mm X screw, the acceleration to 0.25G, on a shorter machine (say 18x18" travel) you can comfortably use a 200w motor on the x, and 100w on the y and z.
so if youve got a raptor, phantom, or viper, you should be looking at smaller motors, nothing bigger than nema23/60mm seems to be needed to achieve dramatically improved performance over steppers.
