I need help on how to copy toolpaths from one file to program another part that is simular with slight geomitry changes in order to save time.
Thanks in advance for any help
Charles
Charles
under the camworks tab you can export the tool path save it somewhere you can find it. Open part 2 select import under the camorks tab and select the file you just saved. As long as the part is drawn in the same orintaion as part 1 is should be pretty close. it will also bring in tools to your tool crib from part 1
