586,077 active members*
3,599 visitors online*
Page 3 of 5 12345
Results 41 to 60 of 87
  1. #41
    Oct 2010
    83
    Quote Originally Posted by jilt View Post
    This is perfect. I have a design that came with my cnc build (kronos) but it cannot handle the length of my table and it sags under the weight of the cables and then binds. Its great for smaller tables but not the 8' one I built. This looks like it would be far better. What is the maximum length you have run with this? I use sketchup more than any auto cad and I'd love the skp file if you would be willing to post it too. Maybe I could resize the model to fit my machine better. Thanks in advance.
    Manage Attachments:............Says this.
    "Valid file extensions: bmp doc dwg dxf gif jpeg jpg mov pdf png psd rar txt wmv xls zip"
    I have the .skp files, but as you see above 'Manage Attachments' will not let me send them. Go Figure. jilt, If you can send me a PM with your e-mail I will send them to you.
    Gene
  2. #42
    Jan 2011
    10
    Quote Originally Posted by gene8522 View Post
    Gene
    Thank you Gene.
    You beat me to it. I'm on the road and can't get to my files anyway. Thanks again
    Roger
    Sent from my EVO using Tapatalk
  3. #43
    May 2005
    1662
    Brilliant ! Thanks for sharing.
    Regarding attachments: I've uploaded audio files to this forum, just needed to upload as a zip.
    Anyone who says "It only goes together one way" has no imagination.
  4. #44
    May 2013
    17
    I am running on a 10' table with no issues. I do have a tray for the bottom of the cable carrier to run in.
  5. #45
    Oct 2010
    317
    Just curious, what holds the sides on? I mean the outermost sides that have the slot cut that allows the motion.
  6. #46
    Jan 2011
    10
    Quote Originally Posted by tjb1 View Post
    Hi tbj,
    The sides are held in place by the rectangular shaped cross section. The cross section is kept in place by two outermost sides. At 1:30 of my video, you can see how one outermost side fits under the edge of the cross section. Hope that helps.
    Roger
    Sent from my HTCONE using Tapatalk
  7. #47
    Nov 2013
    Hi! Nice work!
    I got issues when creating the gcode from the dxf files, but I have no issues when I create gcode from skp using sketchucam. Would you share the skp file ?
    Thanks!
  8. #48
    Apr 2006
    3498
    Use simple conveyer belt and cable tie. works like a treat.
    CNCzone.com-The Largest Machinist Community on the net! Over 300,000 members and growing.
    http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
    http://my-diysolarwind.blogspot.com/
  9. #49
    Apr 2006
    3498
    Someone 3d print
  10. #50
    Jan 2011
    10
    No problem. Just provide an email.
    Quote Originally Posted by mossitebiesse View Post
    Hi! Nice work!
    Thanks!
  11. #51
    Dec 2011
    Sorry - dxf noob question. I use Sketchup & SketchUCam but obviously not enough to be self-sufficient. This is the first time I've tried importing a .dxf file.
    When I import the dxf file, the drawings (which are just lines - nothing filled in) don't allow the SketchUCam Inside Cut or Outside Cut tool to do anything. It's like the shapes are open or something.
    BTW, have you shared the Sketchup file on Google's Sketchup warehouse? 3D Warehouse
  12. #52
    thanks
  13. #53
    Dec 2013
    thanks for the Cable Carrier file nice work
  14. #54
    Feb 2014
    Thanks gene8522!!
  15. #55
    Feb 2014
    Just awsome. just recently got my first hobby cnc table going and would love to use this for some more test cuts! I use the phlatboyz plugin but have no way (that i have found) to import dxf. to sketchup. Would it be too much of a bother to ask you for the skp. files? I'm using metric if that matters for the file.
    Thank You ahead of time, and great work.....Tim
  16. #56
    Jan 2006
    Re: DIY Cable Carrier
    Completely based on rogerquin's design, I have implemented this model on SolidWorks (this is the soft I use). On this version, the dimensions are based on functions, so you can modify the geometry of the model to make a cable carrier with the wished dimensions.
    The variables are in spanish, sorry.
    Code:
    "Altura" = Height of the carrier
    "Anchura" = Width of the carrier
    "GrosorTabla" = Table thickness
    "DiamFresa" = Milling diameter
    Units on mm
    Above all, thanks to rogerquin for his design
    Regards!
    Attachment 230888
  17. #57
    Dec 2004
    48
    Looks like a cool project .Thank You for sharing your design.
    Bruce
    www.wtxrcdog.com
    http://wtxrcdog.blogspot.com/
  18. #58
    May 2014
    bonjour je suis nouveaux sur le site
    pourrais t'on avoir le fichier en pdf
    je ne ces pas les convertir
    merci d’avance
  19. #59
    Mar 2014
    5
    Hi all. Having problems with cable carrier dxf.
    I can import to sketchup but cannot edit it. also of course no g code is created.
    Any help would be appreciated
    ok so I figured it out. Thanks anyway though
  20. #60
    Jan 2007
    211
    Great design! I made a cable carrier years ago, never liked it all that much. Going to make these out of 1/8 lexan. Thanks!
Page 3 of 5 12345
  1. DIY cable carrier
    By sixtyeight in forum MetalWork Discussion
    Last Post: 12-18-2018, 08:47 PM
  2. DIY Cable Carrier
    By epineh in forum Open Source CNC Machine Designs
    Last Post: 03-29-2018, 03:09 AM
  3. Cable carrier
    By Gamble in forum Torchmate
    Last Post: 07-31-2014, 03:21 AM
  4. AC power cable in the same cable carrier with motor cables
    By bandtank in forum CNC Machine Related Electronics
    Last Post: 06-02-2010, 12:06 AM
  5. Replies: 0
    Last Post: 01-22-2010, 07:06 PM
