good work
good work
hi roger iam new to the cnc world i have built my own machine and still learning .... on your dxf cable carrier files i got them and i am haveing truble with the oval ones i'am useing 3.175mm bit = 1/8" wont let me do tool path any help ...
Wrong person I think. Not me.
Cheers
Roger
hi roger iam new to the cnc world i have built my own machine and still learning .... on your dxf cable carrier files i got them and i am haveing truble with the oval ones i'am useing 3.175mm bit = 1/8" wont let me do tool path any help ... or can u send me g-file my email is [email protected] been at this for 4 days now
Hello
Not sure what software you may be using to create your code or your machine software but a quick check of the spacing between pieces may do the trick. If the spaces between the pieces is smaller than the tool you want to use it may not run.
I have found even if the space between pieces is the same size as the tool it may not run with my software.
If the spaces are small in yours respected them slightly larger than the tool. Even .001 of an inch works for me.
If if this is not the problem your having more info from you will prob be required.
Hope me this helps you.
Chris.
güzel çalışma
