586,700 active members*
2,736 visitors online*
Thread: 4th axis
Page 1 of 2 12
Results 1 to 20 of 34
    Jul 2010
    172
    4th axis
    Does V24 pro version support a 4th axis?
    Thank you------Rick
    Jun 2008
    1838
    Quote Originally Posted by rckdef View Post
    Thank you------Rick
    V24 4th axis Index and wrapping, V25 full 4th
    Regards
    Rob
    :rainfro: :rainfro: :rainfro:
    Jul 2010
    172
    Thanks Rob
    If you could explain just a little more---I think i understand Indexing
    but what is wrapping?--Do you know of any indexing tutorials for BC.
    I tried to follow the example in the 4th axis help menu but got stuck!!
    Thanks for your reply-----Rick
    Mar 2012
    1570
    V25 Wrapping
    This link explains how to use the 4 axis wrapping in V25:
    How to Machine Using 4 Axis Wrapping
    Understanding that you are using V24, the software works very close to the same way as V25, just a little bit different.
    1) To setup your job tree for 4 axis wrapping you need to change your stock type. You would do this by RT clicking on Milling Stock > Edit
    Change your stock type from Rectangular stock to cylindrical stock.
    upload photos
    Now you have done this the software is setup to convert all your tool path features to 4 axis wrapping.
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
    Mar 2012
    1570
    Curve Ball
    Here is a step by step on V24 4 axis wrapping.....
    [ame=http://www.youtube.com/watch?v=mTpwUMJSho4]BOB CAD CAM 4 EJE 2 - YouTube[/ame]
    Al DePoalo
    Jun 2008
    1838
    Thanks Al
    Thanks Al for putting that up, saved me a lot of explaining
    Keep up the good work
    Regards
    Rob
    Jul 2010
    172
    Thanks for your patience Al-- The V25 Version is somwhat helpful
    but not what i had in mind. I believe it is sketch oriented. I am working
    with BC inside of solidworks generating model geometry.
    The V24 Version you sent me was a real curve ball-(it was in a foreign
    language?? I have a tutorial in my Help screen with a Model in it,
    I am trying to follow it--I almost get there--but im stuck looking for
    the" rotory index axis origin check box"--I wont give up i'll keep trying.
    Again thanks for your patience--------Rick
    Mar 2012
    1570
    If you are running bobcam v2 and using wrapping, then you need to define an axis of rotation ( I think ). So using solidworks you can create an axis. You can use the intersection of two planes to define an axis in solidworks.
    It s not clear to me what version you are running. Please go to help and about bobcad. Please tell me the version and build number you are using.
    Al DePoalo
    Jul 2010
    172
    Hi Al--I tried to contact you--You were busy so i left my number
    with whoever answered. I finnally have gotten some success with
    4-axis. Am working with BC inside of solidworks. My invoice says
    Bobcam V2/mill 3x Pro. I have been following the tutorial from the
    Help Menu. Its a simple sketch based 4th axis tutorial. I got it working
    fine except i cant get it to rotate. I just used a simple .250 hole
    back 1" from the edge as a sketch. In the simulation i get my 3"
    Dia stock just fine. For the feature-Drill hole-(center drill-drill)-
    Output rotary angle on--Rotation angle 0. Works just fine in simulation.
    I copy the same exact feature and change the rotary angle to 90 or 180
    It will not rotate-I checked the post--all the A are 0. So i tried a Pocket
    feature (a large one) at rotation angle 0 it worked great you can see the stock rotate around the axis as it mills out the pocket. (The axis must be good) ? I tried it at a different angle--No success!!
    WEIRD--- can you help-----Rick
    Jul 2010
    172
    Ok Al--
    Is this what you need
    Version 2.0.1.0 (Build 591)
    Waiting to hear from you------Rick
    Mar 2012
    1570
    Rick,
    Dies your post processor post any rotation moves? I think it might just be a post version. Do you know the name of the post you are using?
    Al DePoalo
    Jul 2010
    172
    Al---The mill i will be useing is a Hass VF-TM2. The choices of post
    processors i have with the software are Hass TM or Hass VF.
    I have tried both post processors on the program still it will not
    rotate when assigned a rotary axis of any degrees. (as described in previous thread)--- Rick
    Mar 2012
    1570
    I know we have had some issues with our post processor page on our website. I think it's up at this time. I recommend you download the HAAS OEM post.
    CNC Machine Post Processors | CAD/CAM Software | BobCAD-CAM
    I think the issue you have is the post you are using is not setup for a 4th axis. So even though you have defined a rotation in your CAM tree, you're not getting anything in the code.
    I recently setup a new computer and do not have the HAAS OEM post to attach here.
    Al DePoalo
    Dec 2011
    361
    Give this one a try. The only issue I see with it is that it does not include the newer multi axis variables so I would cross check the code after it is output.
    Attached Files Attached Files
    Jul 2010
    172
    Al----I downloaded Hass-OEM-post----got Hass-OEM-exe
    opened it got Hass.millPst. I selected it in the program
    Sorry- got the same results---
    Mar 2012
    1570
    Just to clear some thing up.
    You load a drill feaure and program a based off a schetch.
    Then you save the feature load the feature select the schetch.
    This time on the posting tab you change the rotray value to 90
    You post you get no A moves.
    Can you copy the cose you do get and post it in this thread
    Al DePoalo
    Jul 2010
    172
    Here it is Al with the OEM post processor
    O100 (4-INDEX 4.NC)
    (DATE - TUE. 02/12/2013 , TIME - 08:38PM)
    (POST - HAAS VF)
    (T1 - 0.375 DIA. )
    (T2 - 0.375 DIA. )
    G00 G20 G90 G17 G40 G80 G49
    T1 M06 (0.375 )
    G90 S998 M03
    G00 G54 X1. Y0. A0.
    G43 H1 Z1.6 D1 T2
    M08
    G81 G98 X1. A0. Z1.42 R1.6 F3.9929
    G80
    (NEXT CUT, SAME TOOL)
    G00
    G80
    M05
    M09
    G00 G91 G28 Z0
    M01
    T2 M06 (0.375 )
    G90 S1670 M03
    G00 G54 X1. Y0.
    G43 H2 Z1.6 D2 T1
    M08
    G81 G98 X1. A0. Z1. R1.6 F13.3639
    G80
    G00
    G81 G98 X1. A0. Z0.8873 R1.6 F13.3639
    G80
    M05
    M09
    G00 G91 G28 Z0
    G28 Y0
    T1 M06
    M30
    Mar 2012
    1570
    Well you are getting A0 with both tools so that makes me think maybe a post variable issue.... Do you know how to edit a post? I would need to look at blocks 2 and 3...
    Al DePoalo
    Mar 2012
    1570
    I also think its strange your gerting an A 0 on the drill cycle line and you are not gettinga Y value.
    I think your cam tree is setup somewhere between wrapping and indexing.
    If you are going to use the posting tab for a drilling feature to output a diffrent a value with out setting up an index system or wrapping group you can do that.
    But if you have cylindrical stock setup or have defined an index system you do not edit the rotation value on the posting tab.
    Al DePoalo
    Jul 2010
    172
    Al--I do not understand what you mean about useing the posting tab
    to set up a feature----(what do you call the posting tab).
    Anyway if you would like to edit the OEM post I think i can follow you
    on that one--I opened it in note pad--- line 273 is Rotary Axis
    Question about line 430 and 431--My Hass has a maximum RPM
    of 4000RPM--should these lines be changed to 4000??
    Let me know----Rick
Page 1 of 2 12
  1. Replies: 1
    Last Post: 11-17-2015, 07:37 PM
  2. 5-axis, 4-axis, and 3-axis CNC Router manufacturer
    By roctech in forum Roctech CNC Routers
    Last Post: 05-24-2012, 09:12 AM
  3. a problem with slaved A-axis moving properly relative to Y-axis
    By zool in forum Mach Software (ArtSoft software)
    Last Post: 07-06-2011, 03:45 AM
  4. Compare Catia and MCX2 for multi axis lathe/4 axis mill
    By bob1112 in forum Uncategorised CAM Discussion
    Last Post: 10-11-2008, 01:15 AM
  5. New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter
    By the__extreme in forum CNC Wood Router Project Log
    Last Post: 02-26-2007, 09:58 PM
