I have built a new 3 axis mill machine, however my axes has a small angular error.
In other software (which I don't like there is a formula axis correction where you can compensate for angular error and square up your machine.
another use is if the stock is not being held strait then I can correct the coordinate to the work piece coordinate. I do that by sampling the stock using a Z zero plate sensor.
What is the equivalent in linuxcnc?
