586,094 active members*
3,943 visitors online*
    Jan 2009
    9
    Mazak Slant turn
    Hi all,
    We have a slant turn 35n (T32-3 control) that is suddenly misbehaving.
    We can run it in spindle mode just fine but after using the driven tooling when we try to switch the spindle axis mode off it will not disengage and stays stuck with the spindle axis light flashing.
    We can get it back to 'turning mode' by removing the bracket with the two roller switches on (attached to the spindle axis 'stepper' motor gearbox) and pressing the spindle switch, this then forces the machine to activate the piston that disengages the spindle axis motor and re-engage the main motor.
    The valve for the hydraulic piston & the switches all work (not stuck open or closed), but for some reason it won't switch back by itself any more without us messing with it like this.
    Hope that makes sense, it sort of did as I typed it!
    Many thanks.
    Dave.
    Jan 2017
    Re: Mazak Slant turn
    Have you already solved that problem because I have a similar problem like yours but the c axis hidraulic piston that clamps the motor, for some reason it wont return to the unclamp position when i orient the spindle and I dont know where the problems comes from. Need Help.
  1. Mazak slant turn A.T.C. with 6t-b fanuc
    By tiromik in forum Fanuc
    Last Post: 10-25-2013, 10:38 AM
  2. Need opinion on old mazak slant turn
    By Spencer4114 in forum Want To Buy...Need help!
    Last Post: 09-28-2013, 08:59 PM
  3. MAZAK SLANT TURN-28
    By CHANDRU in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-09-2010, 10:45 AM
  4. MAZAK : SLANT TURN 40N / T-PLUS / 33 EMG STOP
    By iNUC in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-29-2009, 04:26 AM
  5. mazak slant turn 40n
    By intermax in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-04-2007, 09:16 AM
