586,121 active members*
3,793 visitors online*
Results 1 to 6 of 6
    Apr 2012
    126
    encoder repair
    can anyone tell me how much an encoder would cost to repair or replace ?
    Feb 2007
    664
    my crystal ball is broken !!
    depends on what you need to replace
    from a few dollars to a few thousand dollars ,
    24221
    US Digital $25.00 up, Heidenhain start at around $1K.
    Al.
    Albert E.
    Dec 2008
    239
    what is the make ? what is the Encoder number and what is the problem?
    Apr 2012
    126
    its a toshiba jrv 40 it has a tosnuc control . i`m trying to get get in touch with the fellow to get more info .
    24221
    Also it could have commutation track if AC or BLDC motor, the pole count of the motor would have to be known for a replacement?
    In some cases the encoder has to be realigned with the poles if commutation is used.
    Al.
    Albert E.
  1. Broken BridgePort Encoder, Need new encoder or ServoMotor w/Encoder
    By TNBG_LTD in forum Want To Buy...Need help!
    Last Post: 03-18-2020, 08:54 PM
  2. Steep servo motor (encoder) repair bill? advice please!
    By aaronmk in forum Servo Motors / Drives
    Last Post: 08-29-2011, 07:51 PM
  3. Repair or buy????
    By mcindustria in forum Linear and Rotary Motion
    Last Post: 09-20-2010, 10:51 PM
  4. Replies: 18
    Last Post: 08-21-2009, 06:46 AM
  5. Replies: 0
    Last Post: 07-22-2005, 09:51 AM
