586,892 active members*
4,416 visitors online*
IndustryArena Forum > MetalWorking Machines > Shopmaster/Shoptask > Quick change tool post reccomendations
Results 1 to 7 of 7
    Dec 2012
    Ordered a Patriot machine and am buying some tooling. Looking for recommendations on a quick change tool post that fits the machine. Any experience with these and if the Phase II Chinese built are any good.
    Dec 2011
    21
    Get a wedge type. I got a piston type initially and found it to have very poor repeatability. I bought a wedge type and it is much better. Also, you will have to do some modifying of the compound and or QCTP to mount it correctly. I found the BXA size to be about right. Phase 2 is a good brand. You might want to check out cdco.com. Good prices and decent quality. That is where I bought from and I am quite satisfied.
    Aug 2012
    27
    I use a Dorian AXA and built a riser out of 6061.
    Oct 2003
    927
    Hi Timbob, Tropopv,
    Could you guys post pictures of your QCTP setups?
    Thanks!
    Shoptask rebuild:
    http://www.cnczone.com/forums/showthread.php?t=2139
    Home built gantry router:
    http://www.cnczone.com/forums/showthread.php?t=5049
    Dec 2012
    Thanks for the input. Figured the Phase II would be on par with the machine itself. Just didn't want to end up with sub-par equipment. Pics of you setups would be great.
    Aug 2012
    27
    Quote Originally Posted by Bloy2004 View Post
    Hi Timbob, Tropopv,
    Thanks!
    Feb 2009
    281
    Quote Originally Posted by tropopv View Post
    Nice job on the base- we still use the original compound setup for manual projects, but for CNC work, the rigid post base is better.
  1. hardinge l18 quick change tool post
    By sumterdad in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 03-25-2014, 04:54 PM
  2. Quick-change tool post
    By cnczoner in forum Uncategorised MetalWorking Machines
    Last Post: 08-24-2010, 05:26 AM
  3. Which Quick Change Tool Post??
    By willio in forum Shopmaster/Shoptask
    Last Post: 08-14-2009, 02:19 PM
  4. A2Z CNC Quick Change Tool Post
    By Metaltinker in forum MetalWork Discussion
    Last Post: 12-06-2008, 07:55 AM
  5. Quick change tool post
    By mak in forum Shopmaster/Shoptask
    Last Post: 03-07-2008, 07:00 PM
