586,123 active members*
3,359 visitors online*
IndustryArena Forum > CAM Software > MadCAM > how to force M0 between toolpaths?
    Jan 2009
    49
    Question how to force M0 between toolpaths?
    I have a part that requires tapping many holes.
    I don't have a tapping head.
    I defined a toolpath that drills all the holes, now I want to insert my spring loaded tap guide into the spindle and define toolpaths that move to the center of each hole in turn, and pauses the program at each hole so that I can manually tap the hole. I would hit cycle start each time to move to the center of the next hole....
    Is there a trick to achieve this without editing the G code?
    I have thought of altering the tool number of the tap guide between each hole, and I have thought of using MDI to manually type in the G0's into Mach. Is anyone doing anything more automated to force an M0 into a toolpath?
    thanks....
    Dean
    Jun 2009
    135
    Find and replace in a text editor may possibly work. Find X, and replace with M0 X.
    Mar 2004
    1661
    You can also make a special post processor for your threading operations that makes the stop and no threading. Make a copy of the post you are using and play around. It's just a plain text file so any simple editor will do the work.
    Apr 2003
    1357
    You may be interested to know that the ability to run drill cycles, including tapping, is planned for madCAM 5.
    Dan
  1. St-20 drawtube force ??
    By Machiner1 in forum Haas Mills
    Last Post: 11-16-2012, 07:54 PM
  2. Cutting force
    By vojnik in forum Mechanical Calculations/Engineering Design
    Last Post: 03-06-2010, 10:52 AM
  3. Pre-Loading force
    By semo in forum Linear and Rotary Motion
    Last Post: 03-28-2009, 03:39 AM
  4. Need to know how much force in psi
    By RedDog22 in forum Mechanical Calculations/Engineering Design
    Last Post: 01-05-2008, 11:32 PM
  5. Air cylinders, PSI & Force they have ???
    By Chris D in forum Mechanical Calculations/Engineering Design
    Last Post: 05-01-2006, 05:23 AM
