I am hoping some here has seen this issue before. So after 5 years I finally decided to try a diy cnc. So her is the situaction.
I have the machine build. motor hooked up, boards connected, mach 3 loaded etc. I can jog in mach 3 fine.
I loaded my code and it would not come out right. I came up a weird thing happening on my x axis motor.
If you go to my soft panel and press and hold x+ it moves fine. But if I press and release the x+ , and then do it again, and then again, it will move x+ direction, then x - direction, So when I hold it it moves the direction I'm telling it. if I press and release it will go + or - x? Anyone seen anything like that?
