586,055 active members*
4,324 visitors online*
    Feb 2012
    28
    Larkin System 50
    I am so excited, I just bought this system complete for $3,500.00 and I hope to go get it tomorrow.
    ---Edit--- Here is what the add Stated
    66"x55" Larken Automation CNC System 50 machine
    66"x55"
    Larken CNC machine everything on machine table and machine included. Fully functional
    complete with documents which are also on website
    starcam program on computer
    3-D digitizer probe
    computer comes with software to use the machine
    assortment of bits
    z-axis controller
    3 axis controller
    delivery and setup extra
    more info on parts, software....etc
    ---End of Edit---
    I will also be selling the Solsylva Table that I was building with all the electronics I have for it.
    Doug
    24221
    Is that the DOS version or Windows?
    Al.
    Albert E.
    Feb 2012
    28
    Al.
    I think it is Windows, but not sure, it also has Starcam with it, as well as a 3-D digiting probe, and about $1,000.00 worth of tools with it
    Feb 2007
    966
    Thats a machine we built in 1993-1994, I think its been upgraded to Starcam, but I have a new USB version or Starcam if you ever want to upgrade.
    I sent Lenny down to get you going. Was he a good help ?
    Larry K
    Feb 2012
    28
    Quote Originally Posted by Larken View Post
    Larry K
    Hi Larry,
    It does have starcam, and I am very happy with it.
    I met Lenny at his shop and he was amazing in helping me learn about the software.
    I need to rework the wiring on the routers as the XY Home axis is in the Back left side, instead of the front left side, also I will need to replace the X Axis limit switch, as it is broken, other then that this is an amazing table.
    I am planning on switching the MDF worktop with 1x4 planks, so that I can place clamps imbetween the boards.
    Thanks again
    Doug
  1. Looking for ATC system
    By declanhalpin in forum DIY CNC Router Table Machines
    Last Post: 10-21-2012, 02:52 AM
  2. What CAD/CAM System?
    By leepez in forum Uncategorised CAD Discussion
    Last Post: 04-19-2009, 02:43 AM
  3. Converting DSP controller system to Mach based system.
    By Marwell in forum Machines running Mach Software
    Last Post: 12-20-2008, 12:00 AM
  4. can you use this cam system
    By cob in forum Xylotex
    Last Post: 04-15-2008, 01:55 PM
