587,035 active members*
3,071 visitors online*
IndustryArena Forum > Employment Opportunity / RFQ (Request for Quote). > RFQ (Request for Quote) > I need a prototype part turned, hobbyist?freelance? please quote
    Oct 2007
    Hello, I am looking for quotes on a single part. It is a shaft about 16" long with a couple of shoulders and some threads. Any mild steel will do for this part. Its for a prototype machine and there may be more work to come.
    There are some bearings going on it so some of the tolerances are a bit tight. I am not great with specifying tolerances, so if they seem odd, just email me to discuss. Also its for a high speed application (7-8000rpm) so runout between cylindrical sections must be an absolute minimum. The threads are for a standard N-06 locknut (1.173" major diameter, 18tpi).
    I have attached a drawing, and I can email a .sldprt or .dxf of the file so you can see it better.
    Attached Files Attached Files
    Feb 2012
    55
    Sent you a PM.
    Regards.
    Mike Schetterer
    Finegrain Metalworks
    (425) 681-4732
    Oct 2007
    I have found a supplier for this part. Thanks to all who took the time to reply.
  1. RFQ for turned part
    By fastolds in forum RFQ (Request for Quote)
    Last Post: 11-22-2011, 05:04 PM
  2. NEED A QUOTE - small aluminum prototype 3.5" long Drawings attachment
    By Greg Koziol in forum Employment Opportunity
    Last Post: 05-28-2010, 04:50 AM
  3. Single unit prototype quote
    By tjd10684 in forum Employment Opportunity
    Last Post: 07-17-2009, 03:35 PM
  4. RFQ quote /prototype
    By Motorcoach1 in forum Employment Opportunity
    Last Post: 02-21-2008, 07:35 PM
  5. Quote Please Prototype
    By Bluesman in forum Employment Opportunity
    Last Post: 07-04-2007, 06:09 PM
