586,732 active members*
3,049 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Conversitional mode cutting a .5 pocket w .375 mill causing "Tool to big" alarm?
    Feb 2011
    53
    So I am trying to use a .375 mill to cut a .5 in wide slot and using conversational programming in "frame 2p" (#8) and "Pocket" (#4) mode and every time I go to start cutting the mill shuts off and says "tool too big" on the display!
    Is there some secret rule I am missing? I have tried setting the radius setting from 0 to .5 and that made no difference. ANy ideas?
    THanks
    God bless...
    Mark
    May 2004
    4519
    Is this programmed with G41/G42 cutter comp?
    Apr 2009
    16
    Hi
    You do not say if you are using Ultimax or WinMax but if you are Using WinMax have a look in your Program parameter settings. Go to Milling 1 and set your Blend offset and Blend overlap to smaller values. If you are using the frame and Slot milling modes the machine uses this values to blend in to the programmed path/milling mode. This means that if the amount in the overlap is to big there is not enough room for the milling cycle to blend into the programmed path.
    I is also know in the ISO codes as soft in and soft out when picking up the G41 offset in a radius.
    Hope this help
    Feb 2011
    53
    Quote Originally Posted by Advena_SA View Post
    Hi
    Hope this help
    Hi, I am programming in Conversational mode via the keypad on the stock mill control cabinet. (I am pretty sure the KMBX-1 is too old for Winmax or Ultimax, isn't it?)
    Feb 2006
    175
    Your "blending Radius is too big.
    Reset it in your "milling Parameters" to less than .06 ( .5 - .375) /2= .060
  1. Replies: 1
    Last Post: 11-30-2011, 07:51 PM
  2. Replies: 0
    Last Post: 11-25-2011, 12:32 AM
  3. Replies: 0
    Last Post: 09-13-2010, 07:36 PM
  4. PMC-ALARM 202 "Commanded Tool in Spindle"
    By moldmker in forum Mori Seiki Mills
    Last Post: 04-23-2009, 04:58 AM
  5. Replies: 14
    Last Post: 01-08-2007, 06:10 AM
