586,060 active members*
4,594 visitors online*
IndustryArena Forum > CAM Software > Esprit > Good Post for Trevisan Machine?
Results 1 to 2 of 2
    Feb 2013
    I am looking to see if anyone has good post for a Trevisan Machining center with U axis head...? Esprit cannot figure out how to modify a post to create a consist program to reduce errors and
    Operator edits..
    Feb 2004
    142
    how do you set up your U axis machining? are you looking to do milling and turning with the same post or do you use the trevisan to just do the U axis boring? I've done posts for U axis machining on a Mori MH-503 with D'Andrea head, used work offsets for each port center and programmed them with a custom U axis post I built myself...
  1. what backploter for a Trevisan
    By stiles72 in forum NCPlot G-Code editor / backplotter
    Last Post: 02-14-2013, 08:31 PM
  2. Is this machine any good for what I need?
    By zer0fighter in forum Benchtop Machines
    Last Post: 01-07-2011, 08:57 PM
  3. Deep Groove Taig machine would it be a good starter machine
    By Fritzie15 in forum Taig Mills / Lathes
    Last Post: 09-21-2007, 03:37 AM
  4. They look like a good machine
    By cncman2 in forum Commercial CNC Wood Routers
    Last Post: 05-12-2005, 06:37 PM
