I finally got my machine up and running and now my M6 command will only work one time. I know the Mach3 I have now is a newer version than when I created the macro. Did something change with Mach3 that it will no longer work now or any ideas why this is happening? Other command still work and everything else still works, just the M6 stops working after one use. Nothing but a computer reboot will make it work again (and then it still works just once). Restarting Mach does not make it work again, and even restarting the smoothstepper and then restarting mach will not make it work again. A reboot will though (once).
I did not change the M6Start file from what was working before, it was just copied and pasted in on the new computer. It works fine once, but only once, and then no more M6....Other M codes still work and the machine still jogs, and seamingly works fine otherwise.
I am stuck until this is figured out and I am not sure what else I can try.
See this post for more explanation and history and my macro:
Macro for turret tool change on Z axis
