Originally Posted by
haastec
Actually I see all of the posts as quite relevant.
Regarding the calibration, he said that the probe and tool setter were calibrated "quite recently"; I have no idea how long ago that was and who did it. For me, I want to make sure it was done and done correctly.
You are correct that running back to back calibration cycles should have very small errors in repeatability and is unnecessary, but for troubleshooting, I feel that a new calibration cycle is necessary to establish a new baseline. Also, by calibration, I mean indicating everything and then running the calibration cycles.
The original poster needs to do some more homework. The problem needs to be isolated better and some variables (sources of problems) removed.
A few tenths difference in TLO after setting with the tool setter is fine in my book, but anything over .001" variance needs to be addressed. The OP is seeing up to .015".
+1. The recalibration needs to be done after a problem surfaces, not before. It must be verified.
Mike
