586,114 active members*
3,337 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Haas VF-0 Spindle Drive Parameters, Please
Results 1 to 6 of 6
    Feb 2013
    16
    Hi All,
    My VF-0 1993 lost its Magnetek 503 spindle drive recently, and the only replacement available was the upgrade to a GPD515. Came in the mail today, bolted up directly and powered nicely, though now I don't have settings/parameters needed to talk under Haas control. Does anyone have a list of these settings? Just a few more minutes of inputs to the GPD and my mill would be back to shooting chips.
    Your help on this would be greatly appreciated!
    Cheers,
    -Ken
    503.348.4276 or msg.
    Mar 2012
    11
    parameters
    Ken
    did you get up and going with the parameter issue?
    mas
    Quote Originally Posted by roofis27 View Post
    Hi All,
    Cheers,
    -Ken
    Feb 2013
    16
    I did get help in the form of the Haas .pdf document publishing settings for the GPD503, GPD515 and the Mitsubishi spindle drives from a very helpful Mr. Marinovski at Zaritron, LLC (Zaritron) after a search for people servicing VFD drives & CNC machines. I'm a lot closer to making chips again, though still stumped, as the run commands are received, but zero speed signal, possibly from a stop signal present at one of the inputs. I won't get to work on the VF-0 until next Monday, I'm on vacation this week. I'll get the test meter in the back and trace out the signals. I think I'm pretty close... burns me a bit to have to wait so long to wrap this repair up!
    Thanks for your response, and of course, if anyone else would like help with drive parameter programming I'll send the documents I've been given.
    Mar 2012
    11
    spindle
    Yes, Mr. Marinovski at Zaritron, LLC is very helpful-highly reccomented. I remember having to put a tach on the spindle and adjust a parameter to get the spindle speed correct. Sounds like your just about there.
    best of luck.
    mas.
    Feb 2013
    16
    I got it! Two more days of troubleshooting to find the replacement GPD515 was bad. Installation & programming of a second replacement drive and the VF is chopping metal again.
    May 2022
    14
    Re: Haas VF-0 Spindle Drive Parameters, Please
    Hi
    I bought a Haas vf-0 milling machine. 1993
    Unfortunately the parameters and all its settings have been removed. Does not run programs. If you have the original vf-0 device files, please send it to me so that my device can work again. Thanks
  1. 97 VF-3 spindle drive parameters
    By GITRDUN in forum Haas Mills
    Last Post: 09-03-2012, 12:13 AM
  2. Haas Diameter offset and spindle speed parameters
    By speedboarder9 in forum Haas Mills
    Last Post: 01-31-2012, 09:36 PM
  3. Haas VF4 with direct drive spindle
    By Race 10 in forum Haas Mills
    Last Post: 11-19-2010, 07:01 PM
  4. 1993 VF2 Spindle Drive Parameters
    By tbussan in forum Haas Mills
    Last Post: 10-06-2010, 03:59 PM
  5. Tree Yaskawa Spindle Drive Parameters
    By BPT Man in forum Tree
    Last Post: 12-15-2008, 01:39 AM
