586,058 active members*
3,723 visitors online*
    Feb 2012
    vf cooling winter shop use
    I have a 2001 vf-e (similar to vf-0,1). I have it in my shop at home. I do not keep my shop heated in winter (WI) but I do have heat . Does a Haas mill need to use coolant to cool the spindle? If so, can you drain the spindle after use? I was hoping to use the mill a little this winter and use a mister/air unit for lubrication and cooling of the work/cutter. Thanks
    Mar 2010
    1852
    Yes, the coolant does cool the spindle, but you could use it lightly even when no coolant is running. I often run parts without coolant, but would not want to run it for hours at 7500 rpm. Also, if it is that cold there, it will probably not heat up anyway. The heat would probably dissipate very quickly in the cold.
    You may want to check with your coolant provider and see what the freezing point is for your coolant at a given concentration. May not freeze at all.
    Mike
  1. New Laser / Winter
    By Jtron5 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-20-2012, 09:53 PM
  2. Relocating to the USA in winter
    By Attilka in forum Employment Opportunity
    Last Post: 10-03-2012, 08:41 AM
  3. Uograde my wd40 + shop vac cooling system to mist
    By neity in forum X3/SX3/G0619/G0463
    Last Post: 03-19-2012, 03:48 PM
  4. Spindle cooling with PC Liquid cooling system
    By enforcer in forum DIY CNC Router Table Machines
    Last Post: 02-07-2012, 09:02 PM
  5. Winter Project X2 CNC conversion
    By ZOB in forum Benchtop Machines
    Last Post: 11-17-2009, 04:23 PM
