Hello,
I am having problems with the M69 and M68 codes.... I am trying to unclamp (M69), use a bar puller, then clamp (M68). As soon as I unclamp I get an alarm for ( 2060 Chuck UNCLAMP Status ). I even tried it in MDI with same results. Now the machine did come with a barfeeder that I do not have hooked up. It has a jumper wire where the barfeeder plug goes into the machine.... Is there an parameter thats turned on to give this alarm because of the barfeeder not hooked up ? If so any Ideas ?
Thanks !!
