I found a nice new (cheap) brake for my Z-Axis that I though some of you might want to incorporate. I hope it's OK to post about an ebay listing, I have no affiliation with the seller. If you search for Ogura Clutch/Brake you'll find it and it says more than 10 are available. It's a power-off 24VDC brake, and NEMA mounting brakes are very expensive new so I chose this one. I attached a picture of the brake, and 3D model of how I'm mounting mine with a 1/4" extension pressed into the ballscrew shaft. I hope this helps someone, even if your Z-Axis doesn't drop under its own weight it could still save a part from being ruined if you get a fault that kills your control circuit.
