tuning
HI !
:tired:
Am i right that to use this small program (correctly) the CNC has to be set to INCH unit ?
We have a 4020ht with Metric srews and we use it in METRIC as well (what else)
So to set it up correctly i have to use SETP and change the "system" to INCH. Then i can use this Prog. The travel is not really important just the F150 (IPM) and of course M91 M49 (to eliminate the feed rate adjuster pot.)
FADAL VMC4020 HT 1995, Z 28" (if true) , 88HS , 10K rmp , 21 TC geneva /rotary/ , VH-65 (A-axis) ,3ph 400V , metric, NO conveyor, No palette. (+alternative DC AMP)
