586,068 active members*
4,388 visitors online*
Results 1 to 6 of 6
    Feb 2006
    16
    Question DNC between FANUC 16 and CIMCO dnc Max
    Hello.
    I'm getting problems with the remote request function.
    It seems that Fanuc control is not sending DC1 when we push the start button in Tape Mode.
    Has somebody experience with this matter
    Sep 2005
    767
    DC codes in Fanuc 16
    First check to see what I/O channel you're using. If you press the Setting/Offset button, you'll see a setting marked simply "I/O". This number is usually set to "0", but it can be set to "1", or "2" for other serial port channels, or "3" for the Fanuc Remote Buffer.
    If the setting is "0", look in parameter 102
    If the setting is "1", look in parameter 112
    If the setting is "2", look in parameter 122
    If the setting is "3", look in parameter 132
    If the setting is "4", your set up to use the SRAM card slot next to your CRT.
    The parameters listed above are normally set to "0", which is a setting from a chart in the Fanuc operator's manual. A setting of "0" means that a standard RS232 protocol with DC codes is used. Other settings are intended for Fanuc devices like the Fanuc Cassette adapter, the Fanuc portable tape reader, etc.
    Feb 2006
    16
    Sorry, make mistake.
    The cnc is a Fanuc 15 and de I/O device is 0 and in the parameter 102 device number=0. So I think the settings for the standar RS232 has to be in another parameter
    Ninus
    Sep 2005
    767
    Wrong CNC
    The Fanuc 15 uses parameters 5110, 5120, and 5130 to set the communicatons protocol. I recommend that you set "3" in all three of these parameters.
    Feb 2006
    16
    Thanks Dan, next monday i'll tell you how it works
    Thanks again
    Feb 2006
    16
    Ok, Dan.
    It works correctly. Handsnake or Xon/Xoff is redy now.
    The only problem that I have is that I need an Xon character when I push the start button in tape mode and it depends of the maker of the machine, in that case is a Mori Seiki machine and I can't detect this character.
    Any way I introduce an delay in to the pc so I have enough time to change to Tape mode push the start program and wait while the program comes
    Thanks again.
    Ninus
