586,110 active members*
3,281 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Controllers for NEMA 8 stepper motors
    Feb 2013
    27
    I am trying to build an XYZ system that i plan to control through a CNC software like Mach3/LimuxCNC.I needed a controller to run this system and had zeroed in on the Gecko 4 axis drive G540.
    But recently i found that the gecko drive is not recommended for a Nema 8 motor which is the motor that i have in the stages.
    Can you please help me out in finding a NEMA 8 stepper motor controller which should be compatible with MAch3/LinuxCNC? (parallel port interface)
    Also will it be a huge problem (motors burning) if i still use the Gecko drive to run the NEMA 8 motors since the minimum power supply for the drive is 0A and i have a variable power supply?
    Varun
    Jun 2004
    6618
    IIRC I think the Gecko's need a minimum range to operate.
    I don't know if your motors will meet that range.
    You might check with SeeMeCNC.
    They run Mach software with nema 17's.
    SeeMeCNC has the Rostock MAX
    http://shop.seemecnc.com/4-Axis-Step...oard-26706.htm
    Lee
    Feb 2013
    27
    Thanks for the reply.
    The range of operation for the Geckos are 18 - 50V and 0- 3A.
    Seeing the minimum current required is 0A, is there a possibility of working? Anyway i will check that out.
    Also the board that you have linked to are the TB series boards which i have a similar 3 axis one.
    Even these boards require a minimum stepper motor size of NEMA 12.
    Any other controllers that can work with the NEMA 8 motors.
    Jun 2004
    6618
    You are in the range of a small inkjet printer. Check out robotics or eve the Make website.
    They deal with those small motors often.
    MAKE | MAKE magazine
    Lee
    Re: Controllers for NEMA 8 stepper motors
    you can have a look at nema 8 stepper motor at this site:https://www.oyostepper.com/. I am a regualar customer of this site .
  1. Stepper motors NEMA 23 & 34
    By all4anm in forum For Sale Only
    Last Post: 08-18-2016, 01:39 AM
  2. Nema 23 stepper motors
    By woodworker2 in forum Want To Buy...Need help!
    Last Post: 07-24-2009, 10:30 PM
  3. Replies: 2
    Last Post: 07-12-2009, 10:10 AM
  4. USB Controllers & Integrated Stepper Motors
    By tt_raptor_90 in forum Stepper Motors / Drives
    Last Post: 01-29-2006, 11:59 PM
  5. The theory behind stepper motors and controllers
    By abasir in forum CNC Machine Related Electronics
    Last Post: 07-22-2005, 10:15 AM
