586,065 active members*
4,264 visitors online*
    Nov 2012
    139
    Madcam/KMotion CNC Post Processor?
    Anyone using Madcam and have an appropriate post processor for KMotion CNC?
    Nov 2012
    139
    Okay, let me ask this a different way. Anyone using ANY cam package with KMotionCNC? What post processor are you using?
    Nov 2012
    139
    For anyone with MadCAM, here's something to keep in mind. The stock EMC2 post works except for the tool select line, I believe, BUT be careful. MadCAM assumes straight line, linear rapids and calculates clearance underneath the cutter. KMotionCNC moves every axis as fast as possible to the end point. That generally results in a path that is NOT straight, and in my case sent the tool crashing through my model. It's not enough to look at the toolpaths in simulation mode in KMotionCNC. It will show straight lines, but in simulation it only displays the raw gcode points. I think the solution would either be for an option for straight line rapids, or change all the rapids in the post to G01 moves with high feed rates (which is what I intend to do).
    Anyhow, that's just a little warning.
  1. KMotion CNC.net
    By bradodarb in forum Dynomotion/Kflop/Kanalog
    Last Post: 08-15-2016, 03:24 PM
  2. Why does MADCAM post say this?
    By boana in forum MadCAM
    Last Post: 05-10-2012, 10:10 AM
  3. Kmotion Contorller on 2k CNC
    By Tecton in forum K2CNC
    Last Post: 02-04-2012, 03:39 PM
  4. Getting started with Madcam/post to .nc?
    By fieldse in forum MadCAM
    Last Post: 12-10-2011, 11:36 AM
  5. post settings in madcam
    By DerHammer in forum MadCAM
    Last Post: 08-14-2007, 02:53 AM
