586,630 active members*
2,686 visitors online*
IndustryArena Forum > CAD Software > Rhino 3D > Recommendation for hobbyist CAM to got with Rhino 3D
Results 1 to 13 of 13
    Aug 2005
    158
    I am a home hobbyist. After a lot of research I felt that the most reasonable long term "bang for the buck" investment I could make in CAD software was Rhino 3D. I have purchased version 5 and installed it. I'm now looking to fill in the CAM piece of the software chain.
    Does anyone have any experience or feedback using an under $500 CAM software product with Rhino?
    The output of the CAM will flow to Mach3 which will then flow to a KFlop\KAnalog which feeds a DMM Technologies AC servos.
    Any low cost CAM experience or feedback would be appreciated.
    Arvid
    Jul 2007
    177
    For 2,5D I did my own Rhino scripted CAM ...
    and for 3D I use RhinoCam2
    Why reach for speed, when you could have precision instead!!!
    Aug 2005
    158
    Thanks for the feedback. Regretfully RhinoCAM is a little too rich for my budget.
    Jul 2007
    177
    If you want to go just 2D or 2,5D
    RHino includes a Rhino related ( visual basic) derivative engine.
    If you are used to visual basic ... try the following:
    draw a spline.... create an offset line with half bit diameter offset ....
    discretizise in equidistant segments shorter that the physical step width of your router.... store the points youget out of this command with a short header ... a comand line number and the proper g - code and feel well !
    [ame=http://www.youtube.com/watch?v=1xov9uQ8c90]Self Scripted Rhino Cam Module - YouTube[/ame]
    Aug 2005
    158
    Thanks for the video.
    Jun 2012
    Been using Rhino 4.0 for almost a year now and am very happy with the program. Needed a Nurbs capable package to do hull design.
    For CAM I decided upon CAMBAM. I like the control it affords since 90% of what I make are 2.5d parts. But it is able to handle the 3-d surfaces I throw at it occasionally. Took me a bit of experimenting with stepover and scan strategies to produce a nice finish in a reasonable amount of time.
    Jeff
    Sent from my iPad using Tapatalk HD
    Treeline Guest
    The basic MadCam might fit your need, and certainly not in the price range of RhinoCAM.
    madcamcnc.com
    arvidj Guest
    Quote Originally Posted by Treeline View Post
    madcamcnc.com
    Thanks for the recommendation. Regretfully at $750 it is a little rich for my hobbyist budget.
    Aug 2005
    158
    I tried CAMBAM and MadCAM. I love the price of CAMBAM -- ~$150 ... but love the integration directly into Rhino of MadCAM.
    Looking at it for the "long haul", I bit the bullet and ordered MadCAM. Significantly more than I wanted to spend but I decided that the integration and "one stop shop" flavor of it all would be the best solution for my needs. I am just starting out and learning a large number of software tools is not what I had in mind.
    Thanks to those that provided input and suggestions. The insight was appreciated.
    Arvid
    Nov 2012
    139
    Hey, you just bought Rhino, right? Run, don't walk, to www.infiniteskills.com and buy the Rhino5 training bundle. Careful....there's a Rhino4 as well. I bought that by accident and had to repurchase for 5 (they were kind enough to refund me).
    Also, why do you want to fiddle with Mach3? KMotionCNC is fine. It's doesn't have a fancy interface and doesn't have all of the features of Mach3, but it's free and so far it's been extremely reliable and is very good where it counts: the trajectory planner. You can always add Mach3 later on if you really want to, and I had planned on dong that, but after using it for a while now I have no plans to replace it.
    Aug 2005
    158
    John,
    Thanks for the training bundle suggestion. I ordered the DVD's earlier today.
    When I purchased MadCAM I had also made the decision to not use Mach3 and just go with KMotionCNC. The current items that I have on hand are Rhino 5 -> MadCAM -> KMotionCNC -> KFlop\KAnalog -> DMMTech Drives -> DMMTech Servos. I also have the mill. What is missing at this point is the ball screws and all of the associated fixtures to mate them to the mill and of course the Round-To-It to make it all happen.
    Arvid
    May 2013
    Dec 2009
    I use Rhino and SW for modeling and Deskproto for cam. So far so good. and great customer service.
  1. Fellow Hobbyist in SE Qld
    By boana in forum Australia, New Zealand Club House
    Last Post: 07-04-2012, 10:55 AM
  2. CAD/CAM for the hobbyist
    By Trav603 in forum Benchtop Machines
    Last Post: 02-07-2011, 06:29 PM
  3. Rhino Video Tutorial - Create a Diamond Solid in Rhino
    By Robert Schutz in forum Rhino 3D
    Last Post: 06-02-2008, 07:58 PM
  4. Replies: 0
    Last Post: 11-13-2006, 08:55 AM
  5. The Rhino Pen: A Gallery of Rhino Drawings
    By BobWarfield in forum Rhino 3D
    Last Post: 06-08-2006, 05:19 PM
