586,119 active members*
3,761 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Advanti toolchanger problem
    Feb 2013
    4
    Advanti quickdraw toolchanger mounted on a milltronics partner 4 with a centurian 4 controller. the problem is the tool changer will index and keep indexing after it reads the M14 or M15 code for indexing, any ideas what will cause this to happen, the micro switch that keeps track of the index is working properly.
    Oct 2008
    427
    Have you traced the wiring from the switch back to the control to make sure the control 'sees' the input?
    Unfortunately, I don't have a wiring diagram for a tool changer on a Cent4 so I can't help with terminal block numbers, sorry.
  1. Bridgeport VMC1000/30 toolchanger problem
    By de68 in forum Bridgeport / Hardinge Mills
    Last Post: 01-30-2013, 10:52 AM
  2. Minimill Toolchanger Problem
    By Pondo in forum Haas Mills
    Last Post: 12-13-2010, 01:52 AM
  3. Toolchanger problem with Fanuc 10T
    By Indutek in forum Fanuc
    Last Post: 06-07-2010, 06:39 AM
  4. diy toolchanger???
    By marcerasmus in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 10-08-2007, 05:24 AM
