586,108 active members*
3,014 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > RESOLVED! Mach3 MaxNC enabled = 1/4 speed motors , Disabled = no running motors.
    Jan 2013
    I set up a PC with XP and a parallel port so I can get my THC to work. I did a completely new install of Mach3 and included the printer driver. In the port setup and axis selction screen, there is a box labled MaxNC mode. THe max CL mode enabled is checked. My X, Y and Z motor outputs tab shows that pins 2-3, 4-5, 6-7 on port 1 are enabled. My motors however can only run off of 4-5 for Y, 6-7 for X and 8-9 for Z. Also worth noting is that they run are 1/4 speed and I have a good idea on why that is after reading about MaxNC.
    Issue:
    My situation however is that I need simple pulse and direction outputs from the parallel port on pins 2-3, 4-5, 6-7. If I uncheck "Max CL mode enabled", the outputs from the printer port stop working. Jog keys and THC simulator switches still increment and decrement DROs but no output from parallel port -
    Setup:
    3 stepper motors sitting on bench connected to microstepping drivers.
    Breakout board connected to parallel port. Breakout board, drivers and motors are known good from running with a smoothstepper.
    parallel port tests OK - and Speed is shown as excellent at 100Khz when tested.
    If I run with MaxCL mode enabled everything works including THC which I simulated with switches works. but motors at exactly 1/4 speed and pin assigments in motor outputs tab appear to mean nothing.
    Question is:
    How do I get the parallel port working in simple pulse, direction mode
    I would greatly appreciate some help on this - I'm about 12 hours into this problem now. I have a completely fresh XP install and Mach3 is licensed.
    Jan 2013
    Figured it out, needed to reverse the output to active low. Direction and step had to be active low.
  1. 3 of 4 motors not running...
    By mw29715 in forum Uncategorised MetalWorking Machines
    Last Post: 06-03-2011, 02:34 AM
  2. Help Needed - Motors not running
    By indianvirus in forum Mach Software (ArtSoft software)
    Last Post: 11-30-2010, 02:04 PM
  3. Motors not running slow
    By rich_cree in forum Mach Mill
    Last Post: 02-17-2009, 12:20 AM
  4. Running Stepper Motors
    By tmd019 in forum Hobbycnc (Products)
    Last Post: 05-04-2007, 04:10 AM
  5. Stepper motors are still going at the incorrect speed. Need help with Mach3
    By Apples in forum Mach Software (ArtSoft software)
    Last Post: 12-24-2005, 12:29 AM
