I'm looking for a way to modify the direction of a series of lines. To give you a grounding of what I'm trying to acheive, I want to find out if some tool path data can be changed which was greated in CNC Toolkit www.rainnea.com/cnc
CNC toolkit generates code by projecting a spline in the shape of the desired toolpath onto the surface of the model. Once on the surface a series of lines at a user defined interval along the spline is produced normal to surface, the g-code is created for the 5 axies from the lines. This works well for a convexed shape where the head is allways away (on the outside) of the stock, on a concaved shape the head would be in the cavity and because the toolpath is based around normal to surface the head can crash very easily. Think of machining a square pocket with virticle walls and a flat bottom and tight raduis corners, the head would crash into the sides and bottom.
My question is this, is it possible to write a script or macro which can allign selected tool position lines with a user defined point in space? This should allow the opperator to highlight groups of lines which may cause problems and allign them such that they work ok. Can this be done in Rhino or other cad software?
At this point I shold tell you I know nothing about programing.
Cheers
Splint
