586,047 active members*
3,693 visitors online*
IndustryArena Forum > CNC Electronics > Hobbycnc (Products) > Y and Z limit switches inputs not working
    Jul 2011
    26
    Hello everyone,
    I've been using a Hobbycnc EZ board with no problems for quite sometime. It's very easy to setup and works really well.
    A couple of days ago I started having problems with the home/limit switches inputs, specifically Y & Z. The inputs don't pick up the signal when a limit switch circuit opens (I've set all the home switches NC), X switch and emergency stop work fine
    I've searched this forum and I wasn't able to find any threads, and for some reason I cannot access the Hobbycnc Yahoo group, it's virtually impossible, better guarded than the DOD website.
    I really appreciate anyone's help.
    Gustavo
    Nov 2007
    18
    Re: Y and Z limit switches inputs not working
    Sorry I can't help, just finishing my HobbyCNC board up now.
    How do you hook up limit switches to the hobbycnc board? I'm not seeing an obvious on-the-PCB solution, but understand it's capable.
    Where do you wire them into? Straight into several of the pins on the serial port?
  1. Inputs Not Working in Windows 7 32-bit
    By esscott24 in forum Mach Software (ArtSoft software)
    Last Post: 07-06-2014, 05:29 AM
  2. Replies: 3
    Last Post: 11-05-2013, 02:54 AM
  3. How many inputs are needed for limit switches?
    By RPCElectronics in forum Benchtop Machines
    Last Post: 05-31-2012, 10:45 PM
  4. G540 Inputs & Proximity Switches
    By Mikeee in forum Gecko Drives
    Last Post: 04-03-2011, 03:00 PM
  5. Limit Switches Not Working ?
    By Redline in forum Xylotex
    Last Post: 12-13-2008, 03:43 AM
