586,655 active members*
3,021 visitors online*
    Apr 2007
    238
    cold rolled steel for rails
    Ordered some 12' pieces of 3/16" x 1.5" cold rolled steel to make some linear guides for my bishop wisecarver-type v-bearings to ride on. Lining up the opposite end and the middle, this is how much diversion they have on one end. The one on the top is about 5/8" of an inch out.
    Laying the worst one up on edge, on a straight surface, with the crown up, I am able to push the curve down flat. If I drill my mounting holes along each rail, 8" on center, and connect these to my 80/20 aluminum 1.5"x3" t-slot, would that pull enough of the curve out to work? Or should I not try using these at all?
    Wayne
    Nov 2008
    412
    That's what I'm using in my router It work beautifully for wood working. After I'm not expecting +/-.005 tolerance our my machine
    Forget about global warming...Visualize using your turn signal!
  1. Cold rolled steel, flats or square for use as rails.
    By Apples in forum Linear and Rotary Motion
    Last Post: 06-26-2012, 03:51 PM
  2. Cold-rolled rails issue
    By KriegKuts in forum Open Source CNC Machine Designs
    Last Post: 09-05-2011, 04:11 AM
  3. Cold Rolled Steel Uk sourcing?
    By rbs in forum DIY CNC Router Table Machines
    Last Post: 08-14-2010, 11:55 AM
  4. Cold Rolled Steel Accuracy
    By Zach_G in forum Mechanical Calculations/Engineering Design
    Last Post: 11-26-2008, 03:59 AM
  5. Need to cut 1 x 4 cold rolled steel - Product Review
    By jderou in forum Uncategorised MetalWorking Machines
    Last Post: 07-06-2005, 05:24 PM
