Let me explain why the battery is being mentioned and its relationship to machine operation. The TC-1 has a CIB or Control in a box and thus must have a all in one 1/2 size mother board. Every mother board has its own variables/parameters called CMOS which are backed up by a battery. AMong the pages of CMOS are such things as the time and date and type of floppy and type of hard drive or whatever mass storage device is used. If the battery gets weak or dies, the CMOS can get scrambled/corrupted. When this happens the control may not boot or may not load the machine software correctly thus the machine may not work correctly.
You could go to DOS and type in date and enter or time and enter to see if that is correct. But software can still be corrupted.
Also older technology such as a flash card and a Disk On A Chip, have only so many read/write cycles and may fail. If these are used, the C drive or primary master is set to none.
BTW: I have seen 3 types of CMOS batteries on these mother boards. One is a IC called a Dallas Real Time Clock. another was a round can that was a lithium battery soldered to the board. And lastly the coin type lithium battery in a holder such as a CR2032.
George
