I have a 36t pulley, for the z axis. Can I remove the top spanner nut, and thread the pulley onto the remaining threads on the screw? There appears to be plenty of threads that will grab. This is for the stock acme screws.
You need to at least set screw the pulley. Grind a flat on the shaft and it should be fine.
With only one bearing you will have backlash but if the head slides easy it may keep preload on the nut and screw.
The stock screw will have lots of friction so you will need a large stepper and a good amount of reduction to lift the head with a stock screw.
A 13T to 36T and a 500 Oz or larger stepper might work but I haven't seen anyone do it yet.
I have.
Hoss
[ame=http://www.youtube.com/watch?v=hCY47KN1tc8]G0704 Z Axis CNC with Stock Screws - YouTube[/ame]
http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
Excellent, thanks for the video Hoss, that is the same setup I have.
