586,052 active members*
4,217 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Hurco BMC30 wash down pumps
Results 1 to 6 of 6
    Jun 2010
    Hi everyone!
    I recently purchased a 1997 BMC 30. This machine had been neglected for years.
    I pulled the covers off the bottom of the coolant pump and washdown pumps to inspect them. I found the coolant pump to be okay. But the washdown pumps impellars are badly deteriorated.
    They are Yeong Chyuan pumps. The impellars measure 3.385 od. .392 id. and are .500 thick.
    I'd need to replace them but don't have any idea where to find new ones.
    Anyone happen to have a source for these?
    Thanks, Jamie
    Feb 2009
    6028
    are these the multiple stage sheetmetal type? If so, check
    Lost session
    Might find something to fit.
    If they are the single impeller type, throw it away and just buy a new one.
    Jun 2010
    Thanks for the reply.
    They are the single impeller cast aluminum type. I can't afford to just throw my pumps away and buy new ones.
    There must be replacement impellers available somewhere......
    Jun 2010
    So nobody has ever had to replace pump impellers huh?????
    Jun 2008
    71
    I think they press onto the shaft of the pump, at least that is the way they look on our BMC30. You might be able to build something out of steel or stainless if you cant find anything.
    Bernie
    Nov 2012
    96
    Anchovy? Delhi? The city or the Santa Ana neighborhood? Are you from Orange County? I am an old bait hauler.
  1. wash gun
    By k9slayer in forum HURCO
    Last Post: 07-19-2012, 10:10 PM
  2. Hurco BMC30 tool change problem.
    By scottjkolb in forum HURCO
    Last Post: 11-25-2011, 09:34 PM
  3. Replies: 0
    Last Post: 11-12-2009, 03:25 PM
  4. Hurco BMC30 spindle problem
    By electromech in forum Benchtop Machines
    Last Post: 04-07-2008, 10:43 AM
  5. Hurco BMC30 spindle problem
    By javed08 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-08-2007, 05:10 PM
